Thicker Head Gasket after Skimming?
doolie
Post Tue Jul 04, 2006 4:31 pm
Anyone know if after i've fitted a reconditioned (and skimmed) head whether it is essential to fit a thicker head gasket? I guess fitting a standard one will up the compression ratio slightly, meaning i might have to run higher octane fuel?
BMW_YARD
Post Tue Jul 04, 2006 5:03 pm
Depends what how much material has been removed, what is the model code of your engine M20/M40 ?
The cylinder head may be skimmed to a minimum height of 140.6mm for the 318i and 124.7mm for the 320i.
dazleeds
old skool raver
old skool raver
Post Tue Jul 04, 2006 5:09 pm
dealers sell both normal and thicker gaskets for skimmed heads
www.oldskoolfantasy.co.uk
doolie
Post Tue Jul 04, 2006 5:37 pm
It's the 325 engine. I wouldn't mind upping the compression ratio a little really, just I don't want valves getting too close to pistons!
Demlotcrew
Post Wed Jul 05, 2006 10:19 pm
You wont need the thicker gasket on a M20
Got for the extra compression
Andrew
