What is best way to tighten fan viscous coupling?
kevin316i
I replaced the fan viscous coupling today. No problem in loosening it, just a whack of my fist on the wrench. Did the same for tightening it, but is this OK? Does the left hand thread ensure that the nut will not loosen when the fan is spinning?
eko
- Old timer
I justed smacked the spanner a couple of times with a lump hammer,not come off yet
Just tighten it by hand - It won't come off!
Doesn't need lump hammers, loctite, or anything else. I may be the person who tries to remove it the next time!
Ant
- Retired Team Member
110% agreed !Doesn't need lump hammers, loctite, or anything else. I may be the person who tries to remove it the next time!
Email FTW
Gwynleym10
EEK yes please don't tighten it too much!
I ended up taking out my water pump on my IS with it still attached as it wouldn't come off!
now have RS turbo electric fan which was cheaper.....
m-dtech
- Unapproved Trader caution
it should tighten its self with the engine turning ?
kevin316i
Thanks, I'll leave well enough alone
and has "Ford" written on it Uuck! Cheaper for a good reason!Gwynleym10 wrote:
Gwynleym10
No ford written on it it... some German comapny I think! can't rememeber what must go and look.Brianmoooore wrote:and has "Ford" written on it Uuck! Cheaper for a good reason!Gwynleym10 wrote:
