Matt
Really? Not got the Haynes to hand, but when i looked i could not see how the pads came out - figured it was like most cars i'd had, unbolt one caliper bolt, slacken off the other and swing the thing up.there's no reason to change this when changing pads
In order to remove the rear trailing arms, you'll pretty much need to disassemble the rear brakes. The first step is to loosen the caliper bolts. Again, I recommend using a hex socket as opposed to an allen wrench. The allen bolts are 7mm and are in there pretty tight. They loosen fairly easliy with a wratchet though. Once the bolts are all the way loose, simply pull the caliper off the rotor. Don't let it hang from the brake line though.
Hey your right! - brought a 7mm hex socket anyway as i needed the carrier off so i could grind all the rust offKaran wrote:u dont need to remove those allen bolts to change the rear pads..... trust me!
