How Do I Roll Wheel Arches?
fly124t
Post Fri Jun 23, 2006 10:15 pm
can anyone advise on how to DIY roll the arches?
i just bought a car with 17's and i'm sure they need doing
georob
Post Fri Jun 23, 2006 11:54 pm
Grind the lip away slightly leaving about 1 or 2mm
I never needed any arch mods with my ol;d 17's, they were 205's though
smithy318i
Post Sat Jun 24, 2006 12:28 am
with a hammer.
m3ben05
Post Sat Jun 24, 2006 12:29 am
smithy318i wrote:with a hammer.
DAMN, i was just gunna say that lol
cliffybabe
Powered by Nelly
Powered by Nelly
Post Fri Jun 30, 2006 11:54 am
One of mate with a Nova now tried to do it with a rolling pin
I laughed my head off when he told
JazzMan
Post Fri Jun 30, 2006 12:09 pm
This is the proper tool for the job:
http://www.frost.co.uk/item_Detail.asp? ... h%20Roller
liam012
Post Fri Jun 30, 2006 12:13 pm
i must confess
i was guilty of a little diy mself once not to unlike the rolling pin you describe
it actually did the job fine
what i did was got a piece of wood that was round perhaps slighter thinner than ur average rolling ping put about 2 1/2 times the length.
first i cleaned and anti rust treated the inside of the lip
then i filled it up with a lick of p40 i think or something like that
before the compund set i put the piece of wood over the tyre between the arch and the tyre and appled pressure in a sort of see saw sort of angle whilst slightly rolling the wood forward and back
when i was happy i had bent the metal back far enough i stopped and cleaned of the compund that had been squeezed out and let it set.
the arches are still solid on that car
so it worked for me
There are ALOT of reasons why you shouldnt do it this way though so i cant say i reccomend it only i felt it was fine for me.
e30cossie
Post Fri Jun 30, 2006 12:25 pm
i cut the lip off my wheel arch.i have 215 40 17 and lowered 60mm does not rub.
egk2
Post Tue Jul 04, 2006 4:25 pm
Wooden baseball bat and a heat gun.
2.8L M20 Stroker
cliffybabe
Powered by Nelly
Powered by Nelly
Post Tue Jul 04, 2006 4:31 pm
egk2 wrote:Wooden baseball bat and a heat gun.
liking it
nwmlarge
Post Thu Aug 03, 2006 1:10 pm
obviously worth noting either too much or too little heat will cause paint cracking
there was a guide on either mateymatey.com or one of the vw sites on how to make a arch rollign tool using a jack
