brake pad wear sensor
e30-320i
Post Wed Jun 28, 2006 10:07 pm
i've fitted new front pads this evening but didn't realise until i went to fit them that they had no wear sensor so now the warning light on the dash stays on constantly is there anyway to turn the light off (other than a bit of insulation tape over the light)
89 325i touring
stonesie
Post Wed Jun 28, 2006 10:22 pm
either replace the sensor........ or connect the 2 wires together using the wire and plug from the old 1 :wink:
e30-320i
Post Wed Jun 28, 2006 10:33 pm
thanks mate i was hoping that would work i chucked the old one in the boot just incase :thumb:
89 325i touring
smithy318i
Post Wed Jun 28, 2006 10:43 pm
remove the bulb from the cluster.
Lordschleife
Post Wed Jun 28, 2006 11:02 pm
Get a new sensor from ECP only 2 or 3 quid!
Dont solder the wires together like some pikey previous owner had on mine :x :x :x
Cheers,
Robin
stonesie
Post Wed Jun 28, 2006 11:05 pm
mine is done like that by a prevoius owner but they had the decency to use the wire and plug from the old sensor so if i ever want it working again i just need a new sensor 8)
Post Wed Jun 28, 2006 11:31 pm
An E30 I was working on a couple of weeks ago had a plug fitted in the socket on the hub that just had a short loop of wire connected to it.
Didn't look at all home made, so looks like someone, somewhere actually makes a shorting link for the purpose.
e30-320i
Post Thu Jun 29, 2006 4:16 pm
i kept the old pad just incase so if i just cut the plug and a couple of inches of wire from it join the ends and plug it in that should do the trick??
89 325i touring
Lordschleife
Post Fri Jun 30, 2006 1:28 am
Yeah that should work if you really cant stretch to the couple of quid for a new sensor
Cheers,
Robin
