LEAKY WASHER BOTTLE
NigelA
For no obvious reason the main washer reservoir on the grey car started to leak. Replaced the rubber grommet/washer where the pump goes in and checked the aperture on the reservoir was clean before doing this. But it's still leaking. So what can it be please?
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
eko
- Old timer
Plastic split somewhere?
If its the standard type ive got one here if you need it?
NigelA
Thanks, eko. There is no obvious plastic split but will have a closer look at it. The bottle is the dual type found in the 325i.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
NigelA
eko. What I should have written was let me check for the split first and then I may come back to you. Thanks for the offer.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
Dual ones split wher they join together.
Hyperion
my bottle sprung a leak a while back, (single bottle type), i took it out and used bath silcone on the outside on all the joins, shes fine now.
NigelA
Thanks, Hyperion. Will try that one.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
I hate seeing bodged up repairs like this on a BMW.NigelA wrote:Thanks, Hyperion. Will try that one.
Get one from a scrapyard, or try JonB up the road in Bristol.
NigelA
Thanks, Brian. Will ask Jon.
Nigel A
1989 E30 325iT Grey
1990 E30 325iT Blue
1989 E30 325iT Grey
1990 E30 325iT Blue
