Which Strut Bar?
eldarvanyar
Which Strut Bar do zoners have, do they really make a difference and which ones the best for a 320i SE and has anyone seen thsese on ebay?
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... res_IT[url][/url]
ed325i
I have one on my convertable and it does make a difference. I think mine is a spraco one.
ED
ED
M5pilot
That ebay one is exactly the same as an Eibach one in design. This is a hinged design and is far from ideal.
The Sparco's are very good - there are two designs. The cheaper one doesnt look as nice but it's most definately more effective.
Sal
Sal
eldarvanyar
Thanks Sal,
can you explain why the hinges are not so good and what sparco you recommend?
Dunx
It imagine the twin bar one ;)
This is the best strut braceed325i wrote:I have one on my convertable and it does make a difference. I think mine is a spraco one.
ED
georob
why is the hinged brace a bad idea though?
a strut brace is to add rigitity to the shell of the car. If there are hinges to this the cars chassis will still flex when cornering hard even with a hinged bar fitted
A brace like ed325i is solid and won't move when cornering hard so will provide maximum support on the strut towers. The C shape mounting of the bar at each end spreads the load out evenly on the strut towers and won't over load in one small area.
The sparco one piece jobbies are also only £50!!! so about the cheapest out there
georob
ahhh, ok
any recommendations for a rear brace?
gareth
slightly off topic but... have you been welding extra brackets onto your n/s wing to mount your coil and airbox? looks very factory styleeee!ed325i wrote:I have one on my convertable and it does make a difference. I think mine is a spraco one.
ED
ed325i
Yes I have, the expansion tank used to be the other side as well so when I moved it I had to weld in a new bracket and cut the old brackets off. I am going to do away with the old air filter bracket sometime.
ED
ED
Dan318-is
Which strut brace can provide this simon?Simon13 wrote:a strut brace is to add rigitity to the shell of the car. If there are hinges to this the cars chassis will still flex when cornering hard even with a hinged bar fitted
cliffybabe
- Powered by Nelly
Iv'e got this strut brace on my cab and it has made a differenceeldarvanyar wrote:Which Strut Bar do zoners have, do they really make a difference and which ones the best for a 320i SE and has anyone seen thsese on ebay?
oguz327
- Captain Armco
Where can you get the sparco jobbies for 50 sheets dude?Simon13 wrote:a strut brace is to add rigitity to the shell of the car. If there are hinges to this the cars chassis will still flex when cornering hard even with a hinged bar fitted
on the net somewhere! i can't remember where i got mine from! sorry
Dan318-is
what make hommes?
sparco 1 piece, it's steel though which might be too heavy for some at about a kilo
they come in red but like the one in Ed's engine bay
ed325i
Mine was red.Simon13 wrote:sparco 1 piece, it's steel though which might be too heavy for some at about a kilo
ED
Dan318-is
were did you get yours ed?
ed325i
E BAY it was second hand.318-is wrote:were did you get yours ed?
ED
Cotty
- Hartge Crew
I have a Wiechers Twin Tube Strut Brace purchased from the Zone shop
