front valence
tbmw
Post Sun Jun 25, 2006 6:01 pm
have done a search but cant really find what i need
Whats the easiest way to remove the front valence, have a rieger infinity lip spoiler to fit and wanna remove the valence to bolt it up
Thanks in advance
tony
A clear conscience is a sign of a bad memory
Bob_S
Post Sun Jun 25, 2006 6:21 pm
strip off the bumper, then inner arches, and brake duct guides.
strip out the fogs and ducts from the front and the headlight grills. I cant rememeber ecactly where all the bolts are but there arent many and once you start undoing some other will become apparent job can take a short while but do it properly otherwise things will break
also remove the brakcets at the side which hold the ends of the bumper up.
Bollocks to this 24v scrap!
tbmw
Post Sun Jun 25, 2006 6:27 pm
cheers m8
Bob_S
Post Sun Jun 25, 2006 6:30 pm
no worries!
boomer
Post Sun Jun 25, 2006 8:55 pm
Remember the loom that runs across the front of the rad - unclip from holes in shown in photo - hidden behind bumper:
Also bolts/screws under outside headlamps (see above - wing goes over valence at this point)
and a couple of the front upper wing bolts to allow mild bendage.
HTH
