lentec
- Boost Junkie
Post
Thu Jun 22, 2006 4:56 pm
First run without boost.
Made 112bhp at the wheels.
With boost
Made 225bhp at the wheels.
Had a good remap on the rollers makes things sooo much smoother all over the board
Ant
- Retired Team Member
Post
Thu Jun 22, 2006 5:05 pm
good vids Len !!
S/C sounds awesome
power was damn good too fella , that with the "Alex" map or another tweaked version ?
Your local dyno place ?
Email FTW
JoeP
- Location: The Bunge, Waveney Valley, Norfolk/Suffolk border
Post
Thu Jun 22, 2006 5:16 pm
Sweet, that sounds gorgeous! Might have to go the long way home tomight!
Alpine White 325i touring
Saying 'No' to saloon and cabriolet wrongness
gcorky
- Boost Junkie
Post
Thu Jun 22, 2006 5:33 pm
well done m8!
525 sport
charlE30
Post
Very impressive mate
BMW E30 344i track car
BMW F31 335d xdrive
lentec
- Boost Junkie
Post
Thu Jun 22, 2006 5:53 pm
Thanks all
Was prety chuffed with the results.
Ant: That was using a modified version of alexs ignition map with a
new fuel map managed to knock loads out 27 points in places
That was at Cyclone motorsport (nitrous-solutions) in wickford very helpfull people
Andy335Touring
Post
Thu Jun 22, 2006 10:04 pm
Nice one Len, sounds ace
Turbo-Brown
- Boost Junkie
Post
Thu Jun 22, 2006 10:35 pm
Boo, computers at work won't play them!
Was it my fuel map you needed to knock loads out of? Herr Walker said it needed huge amounts of fuel at the bottom which I reckon's probably down to the low air speed due to the large diameter runners
325i Twin Turbo (until 10am 01/12/07
www.air-in.co.uk free M20
exhaust and inlet flange
jonbuoy
Post
Thu Jun 22, 2006 10:46 pm
lentec wrote:Thanks all
Nice vid's geese, look's like your work is paying off
You would'nt be able to PM me the address of the Rolling road as i'm just round the corner in Pitsea
Spoke to the owner of Nitrous solution's before now (Not at Wickford), very helpful bloke and has got a great collection of car's
lentec
- Boost Junkie
e30_Turbo
- Boost Junkie
Post
Fri Jun 23, 2006 6:40 pm
Lennie, you have a brake light out
Well done with results too, is that with the bad blades still?
lentec
- Boost Junkie
Post
Fri Jun 23, 2006 11:00 pm
Cheers mark had no idea
that was with the bad rotors
Alex that was my fuel map that ant setup and was modified to make it work with your ignition map. if that makes sense
Demlotcrew
Post
Sat Jun 24, 2006 9:17 am
Guys im not one to doubt RR results, but from the Vids the guy was on and off the throttle during the Run, and also the way the car is strapped down creates the wrong WHP as the straps pull the car down on the rollers and generate more transmission loss.
Would be interesting what others think?
Dont mean to piss on anyones fire and all that
Andrew
lentec
- Boost Junkie
Post
Sat Jun 24, 2006 6:59 pm
So that would mean that i would be getting more than i did?
The reason it was strapped in that manor was that the back is too low and had no other way to strap it down also had a fiesta straped to the towing eye if that makes any diferance?
My main intention was to get the fuel map spot on, so we wasnt realy watching the power
Turbo-Brown
- Boost Junkie
Post
Sun Jun 25, 2006 8:14 pm
Can only assume they weren't taking the run down losses as they seemed to be braking on the cost down which would make it look like there were massive losses!
