Can anyone shed any light on whether these disks are the correct fitment for my 1991 325 Touring? I've been told that the following is engraved/printed on the disks themselves, the boxes have been binned:
rear say brembo 06. 01 . H AA MINTH 8.44 mm
front say 34. 02 PA 20.4mm MINTH Brembo
Any help muchly appreciated, Brembo's website was about as much use as a 1.6 litre engine in an E30
Do these happen to be the ones that Sajid(?) is selling?
They are probably just bog standard E30 discs, nothing special, GSF sell cheap brembo discs. The front ones you mention are vented, and the rears are solid, the MINTH you mention is minimum thickness, 20.4mm for the fronts and 8.44mm for the rears. New discs are 22mm front, and 10mm rear.
