Cutting out at the lights!!!
Jay07
Post Thu Jun 22, 2006 11:48 pm
Hi People!!
Every so often my car decides to start cutting out when it comes to stand still eg at a red light... the idle tends to waver then out she goes!! Does anyone else get this 90% of the time shes fine but then all of a sudden..... there it goes again..... theres nothing more frustrating than a un-trust-worthy car!!!
Hyperion
Post Fri Jun 23, 2006 12:35 pm
i sometimes have that problem too, i will drive my car a bit hard, and come to a stop at a robot and then the engine cuts out or this one time i had to do a emergency stop and she cut out. 97% of the time she is fine. I think if it gets worst i would check and clean the AFM (air flow meter) and check for cracks in the plastic pipes around the TB (throttle body)
Gwynleym10
Post Fri Jun 23, 2006 4:21 pm
I bet you a can of Carb cleaner that its the ICV or Idle Control Valve.
but also check for vacuum leaks especially in the big rubber hose between AFM and TB
London 2 Cape Town
www.Overlandinthesun.com
Jay07
Post Fri Jun 23, 2006 5:07 pm
Cheers guys!! :) I'll check out the tubing when i get home from work!! Running it today it never cut out once!!! :?
As posted 95% shes fine!! - Now my pain is that some toss#r left a burning butt on my back seat yesterday!!!!! :x Still cant believe it!! Its official i'm not having good day!!! (excuse the winge)
