What do i do now?! =( FIXED!
Post Sun Jun 18, 2006 7:43 pm
Just had a very good day, making my old sport totally standard.
I removed my inverted billys from it and 35mm h&R springs plus Hartge roll bars
i've fitted the shocks and springs onto my auto
Also last week got my G/friends golf going after a thermostat/head gasket failure, so was nice to lay the alpina up for a well earned rest after a stint of daily use, because she was driving the auto. So it's been good to have the £300 shed back
I also changed the fluid on the auto box, now i've gone for a spin and the auto box light is on and in D in Economy mode and it won't change gear. The auto box light is on too :? It will go into reverse but with a little clunk.
So do i find a second hand auto box OR convert to manual, or have i done something!
Gwynleym10
Post Sun Jun 18, 2006 8:07 pm
depends on how much traffic you drive in! Do you really want it to be a manual?
Its probably easier to fine a decent reliable manual box than an auto one...
Taking the box out is going to be the difficult bit, so its not going to be much more work to convert it.
I have a manual central consul if you need it....
London 2 Cape Town
www.Overlandinthesun.com
Post Sun Jun 18, 2006 8:27 pm
i don't or can't afford to break it as i need it! keeps me pina off the road.
Finding good auto boxes is hard work though isn't it?
Thats why i changed the fluid to prolong it's life! :?
glenn
Engine Transplant Services
Post Sun Jun 18, 2006 9:10 pm
you have pm si
stuartgallafant
Post Sun Jun 18, 2006 11:43 pm
Simon13 wrote:So do i find a second hand auto box OR convert to manual, or have i done something!
i'd start by not repeating yourslef several times! maybe you listened to too much tracy chapman, and thought it sounds good to repeat and repeat and repeat?! ...its not!!! :wink: winkeye
but when you top an auto box up, you're supposed to drain it when the box is cold (undriven temp), then refill it at the same temp, start the engine, select all gears a few times and let the 'box drive the wheels when the car is on 'stands, (the engine only needs to be a couple of mins at the most) then turn engine off and top up again to maximum level
the fluid has to get right into the epicyclic gears and all the actuators and pumps, lines, etc...
then it should be alright?
unless, your missus has f*cked it up, and doesnt wanna tell you something?!
Andy335Touring
Post Mon Jun 19, 2006 12:52 am
Bummer, I hope you can sort it out OK mate :cry:
ian332isport
Post Mon Jun 19, 2006 7:24 am
Simon,
I believe Ste has an auto box for sale. It came out of the silver Touring he broke recently. As far as I'm aware the box is fine. He drove the car back from the Lakes without any probs.
Cheers,
Ian.
Cabrio
Post Mon Jun 19, 2006 10:00 am
Hi
Try as advised the top up the oil, it can also be the electronics that cause problems on these, normally wont change gear when cold..
I have a switchable auto box complete with converter and pipes etc for £70
Have 2 boxes one out of sport and another out of standard 325 but will keep one for a spare
H35-IAN
Post Mon Jun 19, 2006 10:28 am
ive just sold a full manual conversion kit to my m8! and changing the gearbox is not a hard job si! if you need anything and i can help though m8 i will , But my m8s currently changing his tourer auto for a manual conversion also.
ian. :cool:
bmw 328i sport e36 :)
Post Mon Jun 19, 2006 5:54 pm
i did it on axle stands! the light came on before changed it, so i thought i'll change the fluid and it might go out, but no. So it could coincidence maybe
sounds like it could be an electrical fault or duff solenoid speaking to the experts today!
Ian can u PM me Ste's number please as i need the car on the road asap and replacing the box might be the easiest solution.
I can pick it up this week sometime providing a gearbox will fit in my alpina's boot :cry: Or are they too heavy?!
I've relegated it to the road not nice enough to stay in the garage!
ian332isport
Post Mon Jun 19, 2006 5:59 pm
Simon,
You have PM 8)
Ian.
Post Mon Jun 19, 2006 6:07 pm
thanks Ian!
Post Mon Jun 19, 2006 6:09 pm
sorry can't really help old chap but if it is of interest to anyone in need of bits for ZFHP22 'box or a exploded diagram then try www.jpat.co.uk this is a company my old man used to use for parts
but evidently it is easier & cheaper to souce a good second hand box
Post Mon Jun 19, 2006 8:28 pm
well it's going up to Phil Crouch at Birds 2moro so they can see whats up, i'll know then if i need to get a box or hopefully it's just a soleniod needed!
HartgeH27
Post Mon Jun 19, 2006 9:56 pm
Si
If you need a manual box I have one which you can have m8 freebee, plus I will try and help with other bits you might need.
Not got an autobox at the moment.
Just another option m8.....
Iain
Post Tue Jun 20, 2006 10:48 pm
Thanks Iain and the other hero's who havr offered.
I now know whats up!
A faulty soleniod inside the gearbox, i'm picking up a spare gearbox off ste 2moro and should have it sorted on friday nite!
my advice 2 E30's are expensive either way u look at it!
stuartgallafant
Post Tue Jun 20, 2006 11:16 pm
glad you've got it sorted mate, even at a cost...
Post Tue Jun 20, 2006 11:18 pm
stuartgallafant wrote:glad you've got it sorted mate, even at a cost...
in my boredom on my weekends off i've done a few more mods! u thought it was bad then, it's even more worse now!
stuartgallafant
Post Wed Jun 21, 2006 12:08 am
oh dear, what did you do?! :mad:
Post Fri Jun 23, 2006 11:12 pm
FIXED!
yay new filter and oil too, nice smooooooth gear changes.
Turned out to be nothing wrong with the box, so the auto box i got this week was for nothing, but i will keep it as a spare.
There is a back up ecu to the main ecu for the auto box. This is to stop the box going into first gear @100mph if the main one fails for example. So the back up one had given up the ghost, so the main ecu went into get home mode which locks it into 2nd gear.
I've just got back from birds too! Big up Phil Crouch hero sorted me right out!
oguz327
Captain Armco
Captain Armco
Post Sat Jun 24, 2006 7:01 am
Fair play Si, viva the auto :)
stuartgallafant
Post Sat Jun 24, 2006 5:56 pm
nicely done there!!
