M40 to M42 Engine Conversion
E30-Andy
Fri Mar 11, 2005 1:14 pm
The gearbox must definitely be different on the 318i M40 engine compared to the 318iS M42 motor. The output shaft is a couple of inches longer.
Does this mean I need to change the propshaft too? Anyone know if there is a difference? How easy is the propshaft to remove?
318iS Cab - Now Sold :-(
318iS - In bits
Porsche 993 4S :-)
Karan
Fri Mar 11, 2005 1:19 pm
hi mate
yes i think the engine is further back in tthe m42 so the output shaft was extended on the box and a shorter prop from the 325i was used (im bout 95% sure this is the case, im sure demlotcrew can confirm this
Karan
