Death By Sub
fly124t
Sun Jun 18, 2006 9:57 pm
Hello,
Can anyone tell me if the parcel shelf contributes towards the strength of the car.
What i mean is, if I cut large bits out of it to fit sub's etc, would it compromise the cars strength?
thanks
carl
maxfield
Sun Jun 18, 2006 10:04 pm
I wouldn't of thought so its only a thin piece of wood
fly124t
Sun Jun 18, 2006 10:09 pm
thats good,
i thought it was made of something stronger,
thankyou
fuzzy
He who sleeps with "Gingers"
Sun Jun 18, 2006 10:14 pm
wood? are you sure its not metal underneath? is it a saloon?
d6dph
Sun Jun 18, 2006 10:15 pm
I think its actually a metal rear shelf, covered in a pressed card section.
Personally i wouldnt cut lumps out of it as it may be structural. im sure someone will give you a definate yes/no answer
fly124t
Sun Jun 18, 2006 10:21 pm
I thought it was metal,
I looked about six years ago i think, ill have a look monday
maxfield
Sun Jun 18, 2006 10:23 pm
Its that long since ive been in an E30 :roll:
Cotty
Hartge Crew
Sun Jun 18, 2006 10:47 pm
d6dph wrote:I think its actually a metal rear shelf, covered in a pressed card section.
Yep.
There is an oval paned that you can take our behind the rear seats, the so called ski hatch thats just tacked in other than that I would do any more
Jay07
Sun Jun 18, 2006 10:58 pm
Yep metal shelf! - i discovered it when dropping new 3 -ways into the shelf - that was annoying!! - As for the oval in the back panel, cool didnt notice it when i was behind the back rest running some cables... I'll have a look again 2moro! That'll come in handy!
I didnt cut out the metal shelf as i assumed it was done like that for a good reason!!
dark_sounds
Sun Jun 18, 2006 10:59 pm
i asked a same question a while back in order to get extra battery access.... answer was no.. loads of reasons... do a search for me being the author :)
Cotty
Hartge Crew
Sun Jun 18, 2006 11:37 pm
Jay07 wrote: Yep metal shelf! - i discovered it when dropping new 3 -ways into the shelf - that was annoying!! -
I boosted mine by inserting some thick mdf between the shelf and the speakers.
Jay07 wrote: As for the oval in the back panel, cool didnt notice it when i was behind the back rest running some cables... I'll have a look again 2moro! That'll come in handy!
I used to run a 12" sub and it helped a lot
Jay07
Sun Jun 18, 2006 11:44 pm
I did think about doing that but the chavs in the area put me off - i didnt wana put them on display more than neccessary!!
thats handy info coz i was gona run a 10" soon and i was thinking about how the sound gona get through!! Nice 1 :D
Cotty
Hartge Crew
Sun Jun 18, 2006 11:51 pm
When I had my sub and 6X9's & amp the rear view mirror was useless as it vibrated so much
cliffybabe
Powered by Nelly
Powered by Nelly
Mon Jun 19, 2006 4:13 pm
dark_sounds wrote:i asked a same question a while back in order to get extra battery access.... answer was no.. loads of reasons... do a search for me being the author :)
Only reason Ali got tyhe answer of no was because he wanted to use his man thong to hold the sub in place.
All jokes a side it can be done but u would have to re-enforce the shelf with bracing as that is part of the car structure, I have seen it cause problems in the ride of the car etc by removing rear sections of metal work.
I would say leave well alone if ur think about cutting it up
fly124t
Mon Jun 19, 2006 8:10 pm
thanks everyone
ill look at other options
Cotty
Hartge Crew
Mon Jun 19, 2006 8:57 pm
fly124t wrote:thanks everyone
Put your 10" in the boot, punch out the center ski hatch and see how it sounds. I think you could port the sub through the rear shelf with some trumpets but you need to talk to someone who knows more bout ICE than me
mark320i
Mon Jun 19, 2006 9:24 pm
the best way is to boot out the hatch and face the sub into the car, sound qualityis better and when people lift down the armrest the sound is better. all depends on what sub and amp you're running mate?
kingcruizer
Mon Jun 19, 2006 9:39 pm
im not 100% but if you cut to much out it can class the car as a cat d right off as it is a main sructual piece of the car, if i were you i would lose the ski hatch and build your sub box with a funnel type front on it and seal it to the back seat pannel by the ski hatch, the sound should then punch through, good luck
Cotty
Hartge Crew
Mon Jun 19, 2006 10:00 pm
mark320i wrote:the best way is to boot out the hatch and face the sub into the car,
I angled my 12" sub in the rear corner of the boot to cornerload it, sounded awsome.
I would really like to build an isobaric box and wire the speakers out of faze. But been years since I have tried to installe any type of system and even my old system is tame these days.
2 ways - kick panels
tweeters - hight in doors
3 ways (6X9) - rear shelf
12" sub boot
300W amp (150rms)
Kenwood head unit powered the front speaker and the sub did the 6X9's & sub
fly124t
Tue Jun 20, 2006 10:33 am
i recon that the previous owner of the my new Is took this hatch out which is why i am getting more road noise
these forums are a great help for someone like myself who does not know a lot about cars
Demlotcrew
Tue Jun 20, 2006 1:37 pm
maxfield wrote:I wouldn't of thought so its only a thin piece of wood
I think you should be banned from giving advice! :roll:
Andrew
chu346
Tue Jun 20, 2006 5:57 pm
Andrew
:lol:
d6dph
Tue Jun 20, 2006 7:20 pm
Andrew
:clap:
