urgent.....ATF fluid
William
Location: Home:Suffolk, Uni: Cirencester, Gloucestershire
Post Sat Jun 17, 2006 4:06 pm
My power steering fluid is very low and i was wondering if someone could advise the best grade and make of fluid, and where to get it from, preferably tonight?
thanks
ian332isport
Post Sat Jun 17, 2006 4:13 pm
William wrote:My power steering fluid is very low and i was wondering if someone could advise the best grade and make of fluid, and where to get it from, preferably tonight?
thanks
Hi William,
ATF is all much the same as long as you get the correct grade. I believe it's supposed to be DexronII, but DexronIII is also fine.
I use Castrol stuff from Halfrauds myself.
Ian.
jmc330i
Post Sat Jun 17, 2006 5:28 pm
What happens if the wrong grade is used? - Im off to find the bottle I filled the touring PAS up with :?
James
'91 325i Sport
'93 318i touring 16v
ian332isport
Post Sat Jun 17, 2006 5:32 pm
jmc330i wrote:What happens if the wrong grade is used?
James,
Not sure to be honest.
I believe you can mix Dexron II & III in a system designed for Dexron II, but not sure what would happen if you put Dexron II in a Dexron III system (probably not much, but you never know).
Ian.
jmc330i
Post Sat Jun 17, 2006 5:40 pm
Found the bottle, it just says 'Power Steering Fluid - compatible with all ATF fluids', but nothing about Dexron II :?
Im guessing it will be ok until I replace the rack for the MOT.
James
'91 325i Sport
ian332isport
Post Sat Jun 17, 2006 5:43 pm
jmc330i wrote:Found the bottle, it just says 'Power Steering Fluid - compatible with all ATF fluids', but nothing about Dexron II :?
Should be fine. I really don't think it's that critical to be honest.
It's not like it's brake fluid or anything :eek:
William
Post Sat Jun 17, 2006 5:51 pm
Ian,
Many thanks for the advice, I will get down to the stealers on Monday. Always like to use original stuff if I can, thats if they carry it!(they must do im sure)
:thumb:
Demlotcrew
Post Sat Jun 17, 2006 7:49 pm
Yeah they have it in stock.
Andrew
William
Post Sun Jun 18, 2006 1:50 am
thanks Andrew :thumb:
