Help needed fitting E30 hard top
E30BM
Is my car hard top prepaired ? Does it need to be for me to fit on vinly hardtop ? 1989 325i Cabrio. I.E do I need to get other bits to fit it ?
Cabrio owners or anyone who knows please hola.
Fal_325i
No doesm't need to be prepared, the hardtops fit's all the convertibles, providing the hood is in the down position, hope you weren't trying to put it on with the softtop closed???
delphini
OK i've a few inquirys first how does the hard-top attach to the car , the two holdowns above the front windscreen ? second , does the hard-tops actually have a headliner like the sedans ???
gazm3
Fixing kit needed.
BMW Hook spanner, another - I think its 12 or 13mm. And 2 No ugly spike's that sit in special hole's either side, near shue box flap under rubber plugs that pull out. These hole's have your electrical connection, for your de-midst screen at the rear.
Your rear fan will not work when your hardtop is on.
The same scenerio at the front with the handles as the soft-top.
Two- man job lifting the hardtop.
Cheers Gareth.
Cheers Gareth.
