i used some stuff from bmw for the piping.Its the same pipe as used on the clutch fluid bottle.It comes as a metre length and is quite cheap.
The connectors to connect to the master cyl are from bmw but you'll have to ask Ian about those as i dont know the part numbers or what they were off.
I got the brake fluid bottle from car builder solutions (
www.nfauto.co.uk).
My exhaust building is coming along ok.The manifolds are on,i will take some pics of them in situe.To be honest if i had taken some snaps of them before i think it would be very difficult to duplicate from.
I have started on the journey to the back of the car.Where my pipes connect to the manifolds i have put in a pair of stepped pipes i got from jetex custom exhausts.They make the system go from 2" (at the end of the manifolds) upto 2.5".Thats also where i have welded in my lamdba (sp?) sensors.This is to the same spec as the original Evo exhaust.
All in stainless steel naturally
