Every time I(she!) use's the passenger door the window doesnt go under the hood, the door shuts but the glass stays outside of the lip pressed up against the hood. If I open the window then shut it it all lines up OK.
Are there any adjustments I can carry out to get this little annoying problem fixed? The hood looks OK but must be sitting low at that side, or is it the window?!?!
