How to bleed brakes that wont bleed properly?
oze30
just did a subframe swap on my touring and the brakes won't bleed properly. they keep bubbling. Even with theself bleed tool.
Can anyone help???
Can anyone help???
diamondwhite
open the nipples mate and let them gravity bleed then try again. by the way those self bleed systems are a pile of w*** get some one to help you mate
Just backing up diamondwhites description of the self bleed things
jonbuoy
fuzzy
personally ive never had a problem with the self bleed kits
oze30
tried doing ti with the pump the pedal style, the mtighten.. and yes I have someone else helping me.. But he... a very reputable mech... can't get them to bleed either!
diamondwhite
hae u damaged a pipe/hose when refitting the axle
ed325i
I had trouble with mine and ended up bleeding them with the engine running so the abs pump was powered up ? and they bleed ok
ED
ED
oze30
no abs.. though the new subframe has abs.. but not connected. Does this effect anything?
Not relevant. I was going to suggest air in the ABS, but not having any sort of eliminates that!oze30 wrote: Does this effect anything?
If you didn't let the reservoir empty, then the rears should just about bleed themselves through gravity.
oze30
so you just fill the resevoir up and open the nipples? and keep topping it up?
Lordschleife
Me neither in fact they've saved me lots of hassle in the past <shrug>fuzzy wrote:personally ive never had a problem with the self bleed kits
I'm talking about the ones that are just a bit of hose with a 1 way valve on the end here (so you still have to keep running round and topping up the reservoir yourself) not the ones that force the fluid in
Cheers,
Robin
Robin
Pressure bleeder is the best tool to bleed brakes, but for a job like this I wouldn't normally get it out the cupboard. Should gravity feed with no problem!
Chris-W
Someone has recommended a vacuum bleeder, ie. suck rather than push. Any experience with these?Brianmoooore wrote:Pressure bleeder is the best tool to bleed brakes, but for a job like this I wouldn't normally get it out the cupboard. Should gravity feed with no problem!
You mean the type that has a tube to the bleed nipple and a bottle that you plug into the compressed air?Chris-W wrote:Someone has recommended a vacuum bleeder, ie. suck rather than push. Any experience with these?
We had one of these where I used to work, started to use it once then it lived on the shelf
The only equipment ive ever needed is a spanner and another foot
oze30
anyone??oze30 wrote:so you just fill the resevoir up and open the nipples? and keep topping it up?
Chris-W
Yep.
Turbo-Brown
- Boost Junkie
If there aren't any holes in the system etc and they still won't bleed, I've had a reasonable amount of success in the past with just wedging the pedal down overnight with all the nipples shut.
No idea why this works but my guess is that any little bubbles rise over time to the highest point and when you release the pedal, they get drawn up into the resevoir / master cylinder.
Worth a go anyway
Worth a go anyway
oze30
If there are holes in it, wouldn't the fluid come out from those when bleeding?
Would the heat used to seperate the flexi/hard lines apart?
???????????????oze30 wrote: Would the heat used to seperate the flexi/hard lines apart?
oze30
i had rusted lines.. so used abit of heat to loosen it up.. the metal hard line that is.. then they came apart.
Just trying to work out why they can't bleed
You used heat to separate the steel brake lines from the flexibles? And then you reused the flexibles? There are less messy and more definite ways to commit suicide!!
oze30
Just heated up the metal pipes is all.. Was told that by a BMW specialist.. as long as you don't melt the rubberBrianmoooore wrote:You used heat to separate the steel brake lines from the flexibles? And then you reused the flexibles? There are less messy and more definite ways to commit suicide!!
i guess that's bad??
Chris-W
If it was me I'd replace the fluid now - complete flush. I'd also replace the flexies & consider replacing the rigid lines as well.
oze30
I intend to.. but need to get the car stoppingso I can.
Z3I
Your flexible pipes have probably perished inside, so are now acting as a valve, keeping air back all the time. Did your brakes squel or stick before, or could you fell them not releasing immediately? thats another clue. Flexies only last so long, preplace them and try again.
Especially if you attack them with a blowlamp!Z3I wrote: Flexies only last so long,
oze30
|Only prob is the T piece on mine has corroded between the piece and the 3 nuts on the hardline.. ( sounds like the matrix!) Is there a way I could cut the main hardline and then flare and put a new male piece onto it?
Chris-W
Yes - easier when the rear beam's off though!
What I would do in your position is build up a new t-piece with the three rigid lines, make the feed line a couple of feet long and pass it over the top of the beam to join it to the front to rear.
beardymat
- Location: sheffield, city of steel, and rust apparently
just a thought to consider
a friend of mine did a brake conversion on his mk 1 golf and could not get the brakes to bleed until someone pointed out he had the callipers on the wrong sides so the bleed nipple wasnt on the top,as air rises it was trapped and no amount of bleeding would get it out. have your calipers been off?
oze30
nope.. calipers swapped with the subframe.. ie as 1 unit.. so hopefully.. not upside down.
This is what I always do. Cut and form mating flares on the original pipe just in front of the LH rear wheel arch and make up a new line to the T piece, new lines to each flexy, and two new flexys as standard procedure. Materials cost is negligible.oze30 wrote:|Is there a way I could cut the main hardline and then flare and put a new male piece onto it?
Lines and flexys on the trailing arms get renewed if they show any deterioration.
oze30
Cheers brian.
How hard is it to do yourself.. or would it be better to get a shop to do it?
Dead easy to do if you have a small tube cutter and the tool to make the flares. Small pipe beber is nice as well, but not essential.oze30 wrote:Cheers brian.
oze30
i need a brake pipe flare tool ins't it? Where do I get the connectors from?
