Front seat removal
AndyTouring
Post Fri Oct 28, 2005 7:43 pm
I know this should be really simple but how do you get the front (standard) seats out of a '93 Touring.
I was expecting bolts like my 635 but they seem to be some other strange fastening.
AndyS
Live each day as if it's your last because one day it will be.
Ceeman
Post Fri Oct 28, 2005 7:47 pm
I think you'll find it's just a plastic cap over the nut?
That's how it is on the saloons anyway.
Post Fri Oct 28, 2005 7:48 pm
it is simple fella, 4 bolts, one at the end of each of the runners, 17mm I think, remobe nuts and lift out seat, if you're lucky enough to have heated seats then maybe some wires but that's it :wink:
panesar_e30
Post Fri Oct 28, 2005 10:33 pm
shouldnt take more than 15mins to get the seats out, its alot quicker than it looks.
Post Sat Oct 29, 2005 12:29 am
E30BeemerLad wrote:it is simple fella, 4 bolts, one at the end of each of the runners, 17mm I think, remobe nuts and lift out seat, if you're lucky enough to have heated seats then maybe some wires but that's it :wink:
And the seatbelt end.
smithy318i
Post Sat Oct 29, 2005 12:37 am
all are 17mm. WD40 helps a lot too!
Chris
Post Wed Jun 07, 2006 9:38 pm
Hey guys, i did a search and this is the closest thread i could find, anyway..
I cant get decent access to the rear bolts holding down the front seats of my 89' 320i tourer.
The plastic mechanism housing on the very sides seems to get in the way, a socket fits on but i then cant get the ratchet or extension bar into it and because of the shape of the runners i cant get a spanner round the bolt head.
When you slide them right forwards should it clear the bolts for access?? are my runners just full of crap??
Any ideas?? I really need to get these seats out!!
Thanks for any help
Chris
Post Wed Jun 07, 2006 9:43 pm
Chris
Fully forward and right up,you should be able to get a socket on them.
AndyTouring
Post Thu Jun 08, 2006 9:43 am
Yeah, you've got to raise the seat up to get at them.
The bolts go right though to the underside of the car so may be a bit rusty & seized but they'll come out ok.
The front fastenings are nuts with plastic caps on. (Helps to look at them in daylight rather than when it's half dark :oops: )
AndyS
Doesntreallymatter
Post Thu Jun 08, 2006 10:24 am
THEDINGBAT:
Cheers, i'll give it a go.
To be honest i forgot the seats lift up :embarassed:
billgatese30
Post Thu Jun 08, 2006 8:47 pm
don't tell me your fittin ghtme in the 6, mine can't have been that much of an improvment
bmwe30mtech
Post Thu Jun 08, 2006 8:55 pm
Andy, be careful when removing the seats from the car not to scratch the paintowrk on the inside of the door. I found this out :( ! Also when fitting the new seats, be careful not to cross the threads. You will want them to be solid in the event of a crash. :)
Paul
AndyTouring
Post Thu Jun 08, 2006 9:37 pm
Had them in & out a couple of times now. The 2 cross head screws came loose so the seat back moved. Loctite seems to have secured them (touch wood).
Chris: if those motors pack up I may have to!
AndyS
