has anybody had their arches done?
bennyboy
my arches are starting to go on the inside lip. dont think that the lip can be saved. but i have seen replacement panels that go right up into the main part of the panel. do you think that just the lip could be replaced somehow? this would bring my paint bill down a bit!
16V IS engine!!!
bennyboy
this is from beavers auto panels. would it be posible to weld it on the cornor where the lip meets the outside face?
16V IS engine!!!
parksie
The replacement panels you have seen need to be welded in place , filled and re-shaped,then repaint the rear panel.Around £500
fazgti
Just had my sport fully redone and i popped in there while they were putting my new rear arches on, it was just like the main arch and not half the rear quarter aswell
Bmwboyo
I have a Hadrian Off Side Rear spare, if needed - there seems to be a heck of a lot to cut out. You could always learn to to the paint job yourself. Haven't had the courage to do it myself yet 'tho!
beardymat
- Location: sheffield, city of steel, and rust apparently
you can fit as little or as much as you want but i always think that you should keep as much original as possible whilst still doing what you set out to do(ie get rid of the rust) in my opinion there is little point going right into the quater panel and i would just keep it inside the flare of the arch as this gives you a line to work to when you blend in the new metal with filler (or lead if youre really old school)bennyboy wrote:this is from beavers auto panels. would it be posible to weld it on the cornor where the lip meets the outside face?
diamondwhite
not sure where some of you get ya prices from but i had both my rear arches cut out and welded back in. they wont use the whole pannel they'll blend it in where they can find a good bit of steel then paint. your lookin as 150 per side any more and there takin the piss mate
dazleeds
- old skool raver
so mattbeardymat wrote:you can fit as little or as much as you want but i always think that you should keep as much original as possible whilst still doing what you set out to do(ie get rid of the rust) in my opinion there is little point going right into the quater panel and i would just keep it inside the flare of the arch as this gives you a line to work to when you blend in the new metal with filler (or lead if youre really old school)bennyboy wrote:this is from beavers auto panels. would it be posible to weld it on the cornor where the lip meets the outside face?
i can expect lots of lead in my back arches when done then??
www.oldskoolfantasy.co.uk
beadle
My arches were not that bad but heres mine....
Very nice pink base coat primer!! Himmm, I think my mate was taking the piss!
bennyboy
they look really good. whats the process?
16V IS engine!!!
H-M3
that looks like a nice job done! where did you get this done? mine could do with the same, how much did it cost ya?
beadle
A good friend of mine did the arches and my other pall painted both rear quaters! Its quite handy when two of your old skool palls work in a body shop!!
I think i cost me - £40 for both repairs and a £80 mp3 player 4 the paint job!! Sorted A!
We used a grinder and got rid of all the rust , Then we treated the bear metal will anti rust compound , then used the smallest amount of metal filler, built up the arch with about 10 coats of PINK primer and then the paint!! Thats it JD!
Mind u i caught the rust at the bubble stage!!
