How much would people consider to be a reasonable price for throttle bodies which fit directly onto the M20 cylinder head?
I've been pretty pleased with the results I've had with mine in terms of razor sharp throttle response so I've been developing them from a production point of view and have had about 80% of the machining work priced up but before I go too much further, I thought I'd see whether it was going to be viable to have them made in terms of numbers.
The basic kit would include 6 throttle bodies, the linkage and fuel rail mountings. The standard fuel rail and FPR would be retained.
I've designed them so that the inlets don't point directly at the servo and also don't point vertically up at the bonnet so people can either use trumpets of their desired length, or run an air box which sits atop the cam cover, although I've yet to look into costs for this.
All bearings are sealed ball bearing units so they're suitable for turbocharging too
Other considerations are an ECU to control the whole lot which Ant is able to supply and map.
If anyone has any thoughts, comments, suggestions or questions then feel free to fire away!
Cheers!
