Negative camper inside tyre wear
Aziz
Post Mon Jun 05, 2006 12:51 pm
Hi
I have lowered my 325 60/40 and I have negative camper where the inside of my tyres all 4 are wearing out.
How can I re-aline my suspenion the tracking is also out.
any suggestions pls
Morat
Post Mon Jun 05, 2006 1:07 pm
Eccentric bushes are available from the dealer.
(from what I've read here, anyway).
You could try a search on "negative Camber" and "bushes" and see what it shows up?
Good luck
Morat
Widge
Post Mon Jun 05, 2006 1:57 pm
The M3 front eccentric bushes ajust the castor angle of the front wheels, they will only have a little effect on the camber iirc. And I don't thingk you can do anything about the reasr, it's all set up by the rear beam, there's no ajustment. They weren't really designed to be lowered beyond 20mm.
lukeb
im not sure if this is right but i think you can get top mounts off a later car which help with the camber, may be a slightly cheaper option than camber adjustment parts. but im not definate.
ed325i
Post Mon Jun 05, 2006 2:36 pm
look here for info on the back >> http://e30m3performance.com/installs/in ... /index.htm
And you can get ajustable front top mounts from ireland engineering and they do the rear adjustable kit
https://secure11.nexternal.com/shared/S ... =430045723
ED
