My S50 conversion.Done !
buster
Fri Jun 02, 2006 8:36 pm
Hi guys,i thought id take some time and take some photos and explain a bit about the conversion i've done.
The engine :
3.2 evo engine + 6 speed gearbox ,55k miles ,one not so carefull owner ! thats why i got it.
I had removed the engine and box from the e36 the day before.
Old engine out :
Dropped it in but didnt realise at the time id need a 5 series sump ! :mad:
Sump hitting the crossmember :
So new pump was needed as the evo one wont work with the 5 series sump.An m50 one was used.
the 5 series sump i recieved a week later from quarry :
Had to remove this baffle thing to fit it,also the oil pump braket for the evo pump needed to be removed from number 5 main bearing cap. :
Engine in !! :
After that the radiator and pipe mods were done to pipe everything up like fuel pipes , heater and coolant etc
Now the electrics :
Ian Haynes supplied me with full wiring instructions and was very easy to follow.The EWS 2 is all wired in also :
Lots of crimping and soldering later and all was done.
I also decided i didnt like the e36 wiring box so i fitted a e30 4 cylinder cover and crammed all the wiring into it. Looks nice and neat,and factory looking.
The prop was shortened and had the e36 part welded on at reco prop,cost about £100.Also i made my own custom gearbox mount to hold it in there as there isnt one that can be used.
Then the next major and probably the hardest part of this conversion the plenum to servo clearance.Basically there is none ! the standard servo wont fit so i fitted an 1.3 MK2 golf servo but it was still hitting so i removed a 2" long by 1" wide piece out of the corner of the plenum.And it fit ! Only problem now i needed a master cylinder to fit,and be shorter than the e30 one as it would hit the intake boot on the plenum chamber so and audi one was found to fit.It fits straight to the golf servo with no mods.As i will be upgrading to bigger calipers on the front i have fitted a 25mm audi mastercylinder instead of the 23mm,which is same size as the stock e30 one.
Heres a pic :
It fits but the brake lines needed remaking to reach,also note that the intake boot still looks very close and wont fit on. :banghead:
So I decided to move the servo over on the bulkhead 0.5" to make some clearance.
Re drilled it all and made the servo fit ,half an inch over.Nice one i thought but then the lever on the inside wouldn't connect to the servo.
So i extended it and re-drilled it.
This worked a treat.
I then seen a carbon fibre plenum on ebay! so i had to have it.
I thought it would fit as i had seen an s50 converted e30 on e30.de so i bought it.It didnt fit :cry: £500 wasted.But then i came up with the idea of shortening the trumpets and putting samco hose inbetween, so heres what it looked like :
So nice one back on track i thought but i couldn't fit the MAF sensor in and i was unhappy with the quality of the trumpets so off it came again and i decided to TiG the old plenum up and fit that.
I may try and remake the trumpets in aluminium and ditch the maf sensor so that i can justify the £500 chunk of carbon fiber sat next to me now on my desk,but later .I want to get this on the road now !
I thought now would be a good idea to convert to an e36 steering rack instead of the crappy e30 one so i did this now before the exhaust manifolds are done.
Got a rack off ebay,pipes off Ian Haynes and made the column joint myslef.
Fuel pump needed changing for an evo one.
Its a tight squeeze but it fits.I fitted rubber around it after i took the pic to make it sound quieter.
A couple of the inside of the car :
Heres a couple of pictures of where im up to now which is all done appart from the exhaust :
Heres the clearance at the servo to plenum chamber :
If it hits then i will just solid mount the engine,but i dont think it will.
The exhaust manifolds are being modded now by someone i know,then i will complete the rest of the exhaust system.I have bought an evo back box but its bloody heavy and a bit too big so will need modding to fit so i may not use it yet.
So to sum it up,theres the exhaust to do and then off for the MoT.
I will paint the cam cover the same as i have the plenunm in that wrinkle paint but im waiting until the exhaust manifolds are on so i dont chip the paint !
I also need to re route the oil cooler as its just cable tied to the bottom of the rad for now but i will move it to where iot needs to be when its on the road.
Many thanks to Ian Haynes and all the other people on here who have helped me.
Sorry about the maaaassssive post !
Comments,questions guys and girls,
cheers
andy
tylerma
Fri Jun 02, 2006 8:44 pm
what a fantastic read mate
glad to see you have stuck with it too
buster
Fri Jun 02, 2006 8:47 pm
thanks Malc,
took my a year to do and an hour to type that lot !!!!
Fri Jun 02, 2006 8:59 pm
Good work Buster :thumb:
It may have taken a year, but at least you know if you wanted to do it again it would only take a couple of weeks :lol:
jonbuoy
Fri Jun 02, 2006 9:02 pm
That really does look like a factory fit in that engine bay of your's, well done mate! :thumb:
I trust all your hard work will not be going to waste winkeye
She will be a beast!
jmc330i
Fri Jun 02, 2006 9:03 pm
Excellent Andy. Great photos as well :thumb:
Bet you cant wait for the manifolds to come back.
How long do you think before its all up together?
James
'91 325i Sport
'93 318i touring 16v
Andy335Touring
Fri Jun 02, 2006 9:08 pm
Yep, top read ! 8)
Good luck with the finishing touches, it's going to be a beast ! :cool:
Slarty_Bartfast
Fri Jun 02, 2006 9:13 pm
Cracking job there chap, well done.. Great write up as well.. 8)
I would love to have that engine in my track car!! :mad:
Now who is this Ian Hanes guy?? I need to talk to him about the brake pipes for the e36 rack.. winkeye winkeye
Slarty
Image Roll Cage, H&R Coilovers, roll bars, WMS 4pots and an M50.
Fri Jun 02, 2006 9:30 pm
:mad:
Fri Jun 02, 2006 9:31 pm
Whats the pipe on the front of your rack here? And hows the fit inbetween the rack and sump mate?
Could do with something similar for mine 8)
ian332isport
Sat Jun 03, 2006 8:06 am
Nice work Andy. Glad to see it's all coming together :thumb:
DanThe wrote:Whats the pipe on the front of your rack here? And hows the fit inbetween the rack and sump mate?
That's a standard 6 cylinder E36 return line (feeds fluid back to the reservoir). It's a bit deceptive in that picture, but most of the pipe sits more under the rack than between the rack and the sump. It is still close and you do need to 'tweak' it slightly to allow it to fit without touching the sump. It's just a case of squeezing it with your hands so it bends a little closer to the rack though.
Ian.
bigpimpin
Sat Jun 03, 2006 9:21 am
Nice one buster, glad to see your almost there!
Wish I could say the same! should get mine back on Wednesday.
www.m3touring.com
ROC
Sat Jun 03, 2006 9:22 am
Buster, that looks excellent mate. You have done a very nice job there, all credit to ya! :thumb:
gcorky
Boost Junkie
Sat Jun 03, 2006 9:27 am
exellent m8,very nice car with all your effort put in.
lookin back would you do it again? :mad:
525 sport
buster
Sat Jun 03, 2006 11:38 am
Hi guys,thanks for the great comments its been a tough job.A lot of credit should go to Ian for all the info he has given me on this im just the one who put it all together :D
There are many jobs that need doing on the conversion and sometimes a rethink is needed on how to get around the problems,now that I have nearly done the conversion i dont think i would do another but i think if i did it would be a lot easier second time round,also a garage would be nice to do it in as its the weather thats kept me from working ,especially over winter.
buster
Sat Jun 03, 2006 11:48 am
DanThe wrote:Good work Buster :thumb:
spot on there,it probably would ! :mad:
Sat Jun 03, 2006 3:41 pm
That is one fantastic piece of engineering! Couldn't imagine undertaking something like that without proper facilities. Very well done!
Sat Jun 03, 2006 4:01 pm
Good work there Buster..
Lot of work goes into the S50 conversion! Its not easy n not cheap.
Get it done n some vids up :cool:
Dan318-is
Sat Jun 03, 2006 4:02 pm
superb work andy, certainly a well built bit of kit this will be!
Sun Jun 04, 2006 12:48 pm
hero! your nearly at the fun time franky bit!
the car will fly!
tim_s
Sun Jun 04, 2006 1:58 pm
very impressive!!! this will be a rocket! you considered the alpha-n chip kits that people have been trying of late in order to run the CF plenum? other things that I've seen done include separating the MAF innards from the plastic casing and attaching it to the entry of the plenum/intake boot. like you say would be a shame not to use the CF plenum, it would prob make an awesome noise!
tim
2.1 318is, MS, LPG. 200bhp, 175ft/lbs GONE!
Boxster, e46 m3, e36 sport touring and alpina B3 3.0
ian332isport
Sun Jun 04, 2006 4:51 pm
tim_s wrote:very impressive!!! this will be a rocket! you considered the alpha-n chip kits that people have been trying of late in order to run the CF plenum? other things that I've seen done include separating the MAF innards from the plastic casing and attaching it to the entry of the plenum/intake boot. like you say would be a shame not to use the CF plenum, it would prob make an awesome noise!
tim
Tim,
Using Alpha N on the 3.2 Evo engine is a very expensive business as you need to fork out the best part of 4k for a Motec system to run the Vanos. It is possible to lock the Vanos in one position, but you end up loosing all the bottom end torque that the Vanos was designed for.
You can remove the MAF sensor from it's tube, but you need to be careful doing this as well. The MAF is calibrated to work in a specific sized tube with known flow characteristics. If you are not careful it will be giving incorrect values back to the ECU. I guess you could have a mapping session to correct for this, but it's something to watch for.
Cheers,
Ian.
tim_s
Sun Jun 04, 2006 7:43 pm
tim
Tim,
Cheers,
Ian.
agreed about the intake tube. in fact he could use an SMT or similar to deal with any difference in readings which would open up a load of doors while at it, using MAP or ability to run any MAF he likes (like a really narrow one!) for instance.
as for the MAFless stuff, didn't pay attention to whether it was a 3l or a 3.2 :oops: , and knowing that a lot of racers etc ditch the MAF on the 3.0s cars, and that people have had success with the plug-in chips on the motronic getting rid of the MAF I thought that might be an easy way out.
nonetheless, i've heard of people running MSS50 without the MAF. i know not that many places can do MSS50 tuning in the UK, but there are a few.
£4k for motec, ouch! don't other brands like autronic/siastuning/tec3 do full dual vanos control much much cheaper than £4k?
tim_s
Sun Jun 04, 2006 7:49 pm
a bit (alright, massively!) offtopic and a bit of a long shot but ian you don't happen to know the length and full specs etc of the s50b30 and b32 intake valves do you? obv i'm aware of stem dia and head dia, but am interested in legth etc. i'm gonna have to try to get one of each 2nd hand i think, they're £50 or so each off BM.
buster
Mon Jun 05, 2006 10:18 am
i was thinking of alpha N but i didnt realise i would have to ditch the motronic.
I thought it was a piggyback ecu like a unichip.
I did think of putting the maf innerds into the carbon box,didnt realise that the tube effected the sensor.
If i just cut the 2 lugs off the MAF then i think it could be slid into the end of the carbon box.This would mean its in the box and therefore fit in the bay and also still in its tube.Only problem then would be i still cant get the filter on !
Heres a picture of the lack of space with it in place.Sorry its a bit blurry :
Even if i move the cruise control (infact i have now) theres still not enough room.
The ABS unit gets in the way also.
adamS
Mon Jun 05, 2006 5:40 pm
Is that a real alpina mister?
Nice work mate. Will be good to see her back on the road again! :cool:
buster
Mon Jun 05, 2006 5:43 pm
adamS wrote:Is that a real alpina mister?
:flipbird: LOL,ive taken the alpina stuff of now,except the steering wheel as i really like it,but i may put the momo race back on.
Shouldn't be long now. :drive:
Ant
Retired Team Member
Retired Team Member
Mon Jun 05, 2006 6:55 pm
Well done M8
top work and excelent write up
Kudos indeed to you and Mr Haynes for yet another "factory" install
Si316
Tue Jun 06, 2006 3:03 pm
buster wrote: Comments,questions guys and girls,
cheers
andy
too many cylinders mate haha!
looking good tho, gutted the the carbon box wont fit. sure you'll get there with it! :cool:
IG: Si316ti
2.0L M10, Twin carbs, big cam
Full send restoration in progress
DieselMeister
Tue Jun 06, 2006 6:46 pm
Nice one Buster - take time to enjoy the fruits of your labour.
And make me an E36 rack joint while you're at it winkeye
bigpimpin
Sun Jun 11, 2006 1:39 pm
Hey Buster, got my car back on Friday, looking great with the rims and exhaust done. Started her up and OMG major bottom end banging!! :cry:
Having a look at your pics up in this thread you said you removed the baffle from the new sump. I don't think I did this so I'm hoping this is what's causing the noise. :roll: If not is something major! :cry:
I'm gonna try to get the sump off today or tomorrow but id doesnt look easy when its in the car.
www.m3touring.com
Andy335Touring
Sun Jun 11, 2006 1:55 pm
Support the engine and lower the cross member, not too bad a job, touch wood it's just the baffle though ! :cry:
bigpimpin
Sun Jun 11, 2006 6:33 pm
Cheers Andy, I was just gonna ask whats the easiest way to do it.
Got all the bolts out but the sump aint coming out. I'll try to get it up on a ramp tomorrow night and do as you suggest.
I hope its the baffle too or it will be expensive! :cry:
www.m3touring.com
rare
Sun Jun 11, 2006 6:37 pm
Im so jelous its not even funny.
buster
Sun Jun 11, 2006 10:20 pm
sandy,i fitted my new sump with the engine in.I just jacked it up off the mounts , so no need to remove the crossmember.I hope it isnt anything bad !!
I had to remove that baffle for it to fit so surely when you put it on, it wouldnt have gone on so i hope its nothing bad.
