how much do they cost???
blingsta
- Boost Junkie
rather than just putting the eta block and the 2.5 head together, i thought it would be best to do the rings and shells first... how much do you guys roughly think they would cost to buy??
Templ8e30
You''l be looking at about £80 for quality new rings and the same again for main and big end shells.
Cheers,
Iain T
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Turbo-Brown
- Boost Junkie
Plus a hone of the cylinders so the new rings have something to bite into
Templ8e30
Forgot about that, absolutely essential to create a good gas tight sealTurbo-Brown wrote:Plus a hone of the cylinders so the new rings have something to bite into
Iain T
blingsta
- Boost Junkie
cheers lads.. wheres the best place to get these from then?
Templ8e30
I got all mine from my local engine recon centre, Goetze rings and Karl Schmidt bearing shells.
Don't forget you'll need new big end bolts are they are stretch bolts and can't be re-used. Best to get these from BMW.
Iain T
Iain T
blingsta
- Boost Junkie
cheers guys
