The engine is supposed to be from a E34 B10, it has the upward pointing oil filter housing which again points to it being from an E34 but it's in no way concluesive.
Well, it wasn't raining when i got home today so i cleaned the block face up and dummy fitted it with an old H/G and a bare scrap e34 head, it doesn't quite get to TDC and locks up
I'm hope fully going to get some pictures of the 'pina head tomorrow to confirm the combustion chamber shape, but it's fairly obvious when you see it in the flesh that it's going to need some shaping. I don't think it will need much taking off at the mo' but i will have to wait and see.
But this brings other problems like measuring what will be the new squish band and taking off the same amount of metal and shape/angle through all six C/Chambers.
So i need to know where to get some suitable putty/plasterseen(sp?) to measure clearances and how much squish clearance should i aim for ?1mm ? 0.75mm ? 0.50mm ?
I also think to do a proper job i will have to measure the CC's of each C/C.
I've read some where that the way to do it is to smear a little grease on the valve seat to help sealing, insert the valves and springs. Cut a square of clear plastic with 4 bolt holes and a small hole to put the water in. Another smear of grease on the cylinder head face and secure it with 4 bolts/nuts and add water with a syringe(sp?) and measure/keep note/grind some more and repeat. Sound's like fun !
So much for getting back on the road by this Sun/Mon
