Headlamp adjustment..
Post Mon May 29, 2006 1:45 pm
Got adjustable height headlights, but the passengers side is sitting a little low in comparison to the drivers side
how do i bring it up level? think it might be stuck on 3 setting perhaps, doesnt appear to move when you turn the adjuster
Post Mon May 29, 2006 3:13 pm
You mean you had ones that still worked?
There's a large knurled barrel around the hydraulis cylinder at the headlamp. This turns to provide a limited range of adjustment.
If you cant get them high enough, there's a threaded rod in the middlr of the adjuster. The ball end at the front of the rod has a slot for a cross head screwdriver, but you have to dismantle the headlamp to use this. Try turning the rod by a small pair of grips, staying well away from the portion of thread that is used.
Post Mon May 29, 2006 5:00 pm
driver's side one still works yeah :lol:
Post Tue May 30, 2006 1:33 am
it actually appears to work.. but just sitting too low. think i know what bits you were talking about to adjust, so i'll give it a pop
