i need the e30 fairies (again)
debse30
HELP!!! My car wouldn't start so i tried to jump start it but LOADS of smoke appeared and there was a smell. My boyfriend thinks its an electrical fault, just wondered if anyone else had had this problem. This car has been more trouble than it's worth.
And no it didn't start!!!
craigieeb
have you checked the obvious, like is it sparking? is there fuel getting to the engine? whip the rotor arm off to make sure there's going to be a good conection, and check the points inside the cap,
what sort of smell was it??
and what colour was the smoke?
M50 Turbo!!!
I shall say no more
debse30
The smoke was a bluey colour and there was like a melting smell!! It's not ticking over so can't really tell about the other stuff!! Will get boyfriend to do the rotor arm..
DAN
was the jump leads connected to the right connections......
bootyman
I was going to say the same as you Dan. It sounds like the smell of the lead melting when you connect them backwards
Karan
ive done the leads backwards thing....
very embarassing it was too
debse30
nah the smoke wasn't coming from the leads?! more in the center!!
Geeman
In the centre of what...?
debse30
not too sure yet goin out there to have another look....
- Homo Hair
debse30
the smoke wasn't comin from the leads boyfriend seems to think it was something to do with the electrics?? But the car hadn't turned??? He's now out there (bless him) taking out the battery to charge it but that doesn't solve the problem.
320Touring
Is it a light blue, almost grey colour?If so, may be oil thats burning?!
If you got no BIG sparks, then you wont have connected the jump leads incorrectly
Check that the battery is'nt damaged (no cracks or splits etc) and that it has enough water in it..
Also check that teh earth strap (from the battery neg (-) terminal) is coonected correctly and not damaged/rusty
Does it make any cranking noises-or do you not even hear the starter motor kicking in?
M3RAGS
she said it wouldn't start! So its hardly going to be oil as the engine was never running!
MY bet is the retarded switching of the leads causing the 'smoke'.
Also, continual attempted started will make the lead to the starter get extremely hot and the same can occur.
You will have to be more specific please.
Sideways S14
Widge
If you connect jump leads the wrong way around it'll fry the alternator which will then produce whisps of smoke. Other electrical components can get fried too so I should think it was that.
