help with a diff code?
fuzzy
He who sleeps with "Gingers"
Post Fri May 26, 2006 10:22 pm
the code on the tag attached to the back of my spare diff reads 1140A4641S. can anyone shed some light as to which numbers relate to the ratio?
thanks.
EThreezero
Post Fri May 26, 2006 10:53 pm
4.64? fook knows geez
*******MERC E240 BREAKING..1998...LEATHER...ALL PARTS*******
mrLEE30
Post Sat May 27, 2006 5:46 am
it means 40 ring teeth divided by 11 pinion teeth making the ratio 4:1, A means it is a replacement final drive, and it is not a LSD.
see i can be fun!!
mrlee
fuzzy
Post Sat May 27, 2006 7:57 pm
when you turn the prop flange should the 2 driveshaft flanges on an lsd turn the same way or opposite directions?
craigieeb
Post Sat May 27, 2006 8:05 pm
L.S.D turns the same way fella
mrLEE30
Post Sun May 28, 2006 12:19 pm
sorry my mistake didn't read your diff code correctly!! :oops:
it is an LSD due to the ''S'' at the end of the code (and it is a replacement diff by BMW due to the A)!! and yes they should both turn same direction unless the diff clutch is knackered.
and the ratio is 4:1
sorry
fuzzy
Post Sun May 28, 2006 12:33 pm
thanks for the info,i wouldnt call that fun but its certainly informative :thumb:
how would that diff alter the performance over the original 3.91 diff.would that be higher top end but slower acceleration or would the difference be hardly noticable?
mrLEE30
Post Sun May 28, 2006 3:49 pm
yep you would gain more top end speed (but unlikely as aerodynamic drag on a 20+year old design really limits top speed) and you would loose a bit of acceleration about 2-3%, so i doubt you would really notice much change.
however on a plus note you may gain the 2-3% back on fuel economy on a long distance run, which is about the cost you save by running with no lights on and not using the windscreen wipers and stereo!! you could save 5-6% or 5p in every pound!! now that is fun!! (assuming you stick to the speed limit like me :piss: )
mrlee
fuzzy
Post Sun May 28, 2006 4:11 pm
well thats that idea blown out as youve probably guessed by now i sometimes speed so fuel economy is at the bottom of my list of priorities.if the difference is that small in performance i might as well keep the original 3.91 fitted and sell this 4.1 :wink:
Jon_Bmw
Dangerous when thinking
Post Sun May 28, 2006 4:28 pm
Erm not sure if i have read MR lees advice right there or not.
the 4.1 ratio WILL give you faster acceleration but less top speed
the 3.91 ratio will give less acceleration but more top speed.
Andy335Touring
Post Sun May 28, 2006 5:20 pm
What sort of maximum speeds are you getting out of each gear ?
Some times going too short geared can actually slow your over all acceleration down due to to many gear changes and not making best use of the available torque/power.
Short gearing is good for in gear acceleration though, especially higher gears like 4th and 5th.
StuBeeDoo
Post Sun May 28, 2006 5:26 pm
mrLEE30 wrote:it means 40 ring teeth divided by 11 pinion teeth making the ratio 4:1,
Surely 40 divided by 11 is 3.63636363 making the diff in question a 3.64??
fuzzy
Post Sun May 28, 2006 5:44 pm
that would explain the roughly 3.7 turns of the driveshaft flanges to 1 turn of the prop flange. :?as for top speed it runs out of steam at about 120-125 mph on the 3.91 diff. acceleration is my priority rather than top end, first gear is almost useless and as im using the correct cosworth T5 gearbox it must be down to the diff ratios.
StuBeeDoo
Post Sun May 28, 2006 5:51 pm
fuzzy wrote:How would that diff alter the performance over the original 3.91 diff.would that be higher top end but slower acceleration or would the difference be hardly noticable?
OK, so I don't have the power you do, but when I took the standard 4.27 out of my Touring and put in a 3.64, my "arse-dyno" didn't notice any difference. It will pull over 60 in second now though, so the 0-60 time may be fractionally quicker due to not having to change into 3rd at 55.
320Touring
Post Sun May 28, 2006 7:09 pm
glad to hear that dude-thinking of going 3.64 myself..
Fuzzy, fitting 3.64 to my 4.27 touring would mean about a 600-700 rpm drop in engine speed at a given road speed in 5th
eg 4.27 gives 80mph @4000rpm
3.64 gives 80mph @3300ish rpm
therefopre the car is higher geared. would sort out your "short first" issue but may make top end a bit longer (relatively!!!)
StuBeeDoo
Post Sun May 28, 2006 7:19 pm
Neil, Hi Dude, how's things?
You won't regret putting in a 3.64. TBH, it hasn't made much difference to my fuel consumption, but it's far more "relaxed" to drive at speed.
The difference between the 4.27 and 3.64 makes 4th (3.64) almost exactly what 5th (4.27) was (if you see what I mean).
Put another way, 5th is now more overdrive, rather than just "top".
It doesn't affect 1st very much, because it's so short to start with. I think the only way to sort that issue would be to put a Sport 'box in.
320Touring
Post Sun May 28, 2006 7:27 pm
[/quote]
hi stuart :D the touring is sweet as dear fellow:-)
Like the sound of 4th seeming like 5th-hammoj28 will tell you the m20b20 pulls lovely from 1k in 5th :D
how goes your touring? i've got several big plans for mine in the offing winkeye :wink:
with regards to the box-fuzzy is using the t5 box to go with the cozzy lump, so I dont know the exact ratio's, however I do know that the 320i had gear ratios (1st 2nd 3rd) that are almost identical to a sport box :cool:
StuBeeDoo
Post Sun May 28, 2006 7:35 pm
320Touring wrote:hi stuart :D the touring is sweet as dear fellow:-)
Sorry Neil, gotta shoot you down there! Agreed 2nd & 3rd are very close matches, but 320i 1st is 3.72, Sport 1st is quite a bit longer - 3.38.
I know about the pulling from 1k in 5th. Before I swapped diffs, I only ever used 2nd 3rd 4th and 5th!.
I'll PM you, 'cos I don't want to go off topic here.
320Touring
Post Sun May 28, 2006 7:38 pm
essbee wrote: Sorry Neil, gotta shoot you down there! Agreed 2nd & 3rd are very close matches, but 320i 1st is 3.72, Sport 1st is quite a bit longer - 3.38.
oh ok :mad: i still win as 2 out of 3 aint bad :D
just to reiterate fuzzy, 3.64 good for top end, 3.91 for eyebulging acceleration
fuzzy
Post Sun May 28, 2006 9:42 pm
thanks for the info guys,bottom line is ill stick with the 3.91 im using at the moment :thumb:
Andy335Touring
Post Sun May 28, 2006 11:47 pm
Andy335Touring wrote:What sort of maximum speeds are you getting out of each gear ?
:wave: :roll:
mrLEE30
Post Mon May 29, 2006 11:05 am
woops, got my maths and my ratios wrong way round!!
i'll get my coat!
:oops:
mrlee
Jon_Bmw
Post Mon May 29, 2006 12:26 pm
mrLEE30 wrote:woops, got my maths and my ratios wrong way round!!
i'll get my coat!
:oops:
mrlee
No worries chap, I couldn't work out whether you were refering to the old diff or the new diff. Anyway all sorted now :cool:
