z3 rear arms and e36 front struts
madmalc
Post Sat May 27, 2006 10:22 am
hey anyone know what exactly i need to fit the z3 arms hubs and brakes to my 316i do the drivshafts need to be swaped altered
also what do i need to put the e36 front uprights on mine do i have to swap bottom arms and what about the strut top mounts
thanks for you info
cheers lee
Paulsimon8
Post Sat May 27, 2006 10:44 pm
Z3 rear arms are bolt on, as are e36 compact rear arms.
the only extra things you need are new handbrake cables.
the e36 front uprights are easy to fit, but you will have major caster issues, Get hold of E30 M3 parts if you can, much better and easier. winkeye
jaistanley
Post Sat May 27, 2006 11:07 pm
I agree that fitting the E30 M3 front struts is a better option, especially when combined with M3 front wishbone bushes.
The only dissadvantage will be that in order to have the same offset wheels front and rear you will need hubcentric spacers (to use the E36 wheels on the E30 M3 hubs I mean).
Incidentally: Why do you need new handbrake cables to fit the Z3 trailing arms? Don't E30 ones fit the hubs? I ask because I am soon to fit M Coupé trailing arms and had planned on using the handbrake cables that are already there.
Any help appreciated.
Jai
madmalc
Post Sun May 28, 2006 12:05 am
i understand camber caster etc i work at a garage and i am some what of a expert on the 4 wheel lazer alighnment gear we have
the e36 bottom arm slides into a mount towards the rear (bottom arm rear bush) iv noticed that on the e36 the mounting rubber hole is dead in the centre were as on the e30 the mount is off centre therfore i think if i was to fit the e30 mount it would push the hub assemble out and forwards pulling the wheel into the centre of the arch
any one wanting four wheel lazer alighnment give us a ring auto repairs on 01482 668088 we can do everything from a nissan micra to a lambo we set up cars for the track westfields kit cars the mx5 turbos we build are rx7's fast road normal road use lowered supspansion set suspension the works can set up to your own settings, factory settings or some were in between a must for every one out there thats fitted new parts suspension wise bigger wheels wider wheels run up a kurb etc
Paulsimon8
Post Sun May 28, 2006 9:31 am
New handbrake cables as a matter of course - your old ones may become damaged, or are already damaged.
New ones are a definate if fitting rear discs anyway as the drum handbrake cable has a different temination on it for operating the handbrake assembly :) winkeye
ed325i
Post Sun May 28, 2006 3:59 pm
So you would need some of these to change the caster??
ED
Post Sun May 28, 2006 9:31 pm
Just changing joints and bushes isnt enough, you need to modify the wishbones to get the wheel to sit in the centre of the arch.
Ideally the wishbone needs to be around 15mm longer from rear bush to hub ball joint
oze30
Post Mon May 29, 2006 11:35 am
What is needed from the e36?
Just the strut and arms?
I realised I could have done the front.. the rear would have been harder.. The local scrappy was getting rid of an e36.. Buggar!
borat
Post Mon May 29, 2006 12:40 pm
http://www.ubersaloons.co.nz/uber3/5lug.htm
should answer all your questions
