heater problem
Cloggy Saint
Post Fri May 26, 2006 12:07 pm
I noticed yesterday that my heater only blows hot if turned right up to full, despite the temp' guage sitting in the normal position. Can anyone shed some light on this?
Post Fri May 26, 2006 10:12 pm
Turn the heater 1/4 of the way from cold to hot and see if the heater water pipes are getting hot. If thety are, suspect that the heater cable has slipped.
Cloggy Saint
Post Fri May 26, 2006 11:40 pm
Cheers Brian, can you tell me exactly which pipes i need to be checking? And where is the heater cable :oops: ?
Post Sat May 27, 2006 12:03 am
You can check the pipes under the bonnet, where they join to the heater on the bulkhead.
Cable runs from the heater control to the flap lever, which is just behind the back of the driver's footwell heater outlet. If you remove the panel above the driver's knees you should just about be able to see it.
