Clutch fluid leak
C33
Post Thu May 25, 2006 9:55 pm
Hi folks, my 318i seems to of developed a bit of a clutc fluid lead, is there a usual suspect fo this sort of leak or i it a case of checking master, slave and hoses in turn to see where it is.
Also is removal of either slave or master cylinders particularly difficult? not had a proper look yet.
Regards
Iain
Post Thu May 25, 2006 10:10 pm
Usually the leak is from the slave cylinder, but its good practice to change both the slave and the master at the same time.
Chris-W
Post Fri May 26, 2006 7:45 am
C33 wrote:Also is removal of either slave or master cylinders particularly difficult? not had a proper look yet.
Regards
Iain
Slaves is the easier of the two. Master can be a bit of a bugger because of access (pedals, dash etc.)
Post Fri May 26, 2006 8:39 am
Chris-W wrote: Slaves is the easier of the two. Master can be a bit of a bugger because of access (pedals, dash etc.)
Take the front seat out.
Chris-W
Post Fri May 26, 2006 8:46 am
Brianmoooore wrote:Take the front seat out.
And fully recline!
C33
Post Fri May 26, 2006 10:29 am
Cheers, me thinks a bit of Image is in order this weekend then...
Regards
Iain
