Problems:
1) The whole of my centre console, including the gear stick and the electric window buttons heat up so much that if you leave your finger on the buttons to long it will probably burn you
2) from cold my temperature gauge reaches half way before i have even done a mile whether the traffic is good or bad, or the day is hot or cold
3) i have checked all the piping and jubilee clips, and looked under the car first thing before i drive it out the garage for leaks but there is none, but the water seems to be evaporating. i have gone through anti freeze, water and coolant which i am on at present, topping up 1.5litres every three days if i do heavy driving.
Surely the above is not normal, any help or ideas Please?
