Bushes...
hairypete
Post Mon May 22, 2006 7:04 pm
hey guys, can someone either point me in the right direction of, or let me know just what i need to redo the whole lot of my bushes please.
just had the mot done, and failed on a few that are startin to go, so i want to do the whole lot. but i also need my lower ball joints doing,
so we want all the anti roll bar bushes, front wishbone sets, anything else i forgot, and everything for the back axel. if anyone knows if powerflex do all of them, and what to order that would be fabulous
ah i guess i gotta go measure me anti roll bar for the diameter first but any help guys, as always will be greatly appreciated
ed325i
Post Mon May 22, 2006 7:08 pm
powerflex do a front and rear kit and comes with all you need. I got mine from here >
http://www.sca-racerally.co.uk/
ED
ed325i
Post Mon May 22, 2006 8:00 pm
They are saying there are 4 size anti roll bar sizes 12/14/16and18 ??
ED
hairypete
Post Mon May 22, 2006 10:44 pm
ok, cool thanks for the help, i will give powerflex a bell tomorrow after i have measured my anti roll bar and get the bits sent out. rather go direct cause then if something is amiss i dont have to go through someone else.
does anyone know if they do the front lower ball joints though? and if not where would be best to get them from???
maxfield
Post Mon May 22, 2006 10:47 pm
I would of thought powerflex do them if not go down to your local auto factor
Simon
Post Mon May 22, 2006 11:03 pm
Powerflex don't do the ball joints, they can be replaced by being pressed from the wishbones, as long as they are the steel ones (not alu) though the cost to replace all 4, it would probably be easier and not much more expensive to just replace the whole wishbone complete.
dazleeds
old skool raver
old skool raver
Post Mon May 22, 2006 11:06 pm
Simon wrote:Powerflex don't do the ball joints, they can be replaced by being pressed from the wishbones, as long as they are the steel ones (not alu) though the cost to replace all 4, it would probably be easier and not much more expensive to just replace the whole wishbone complete.
agreed totaly
bush set is 30 odd quid and loads of grief
new wishbones ecp about 40quid
not how much at stealers but iv never had probs with ecp/gsf wbs
www.oldskoolfantasy.co.uk
oze30
Post Tue May 23, 2006 12:28 am
so the new wishbones have the bushes and ball joints already?
Chris-W
Post Tue May 23, 2006 8:44 am
No - they just have the ball joints in them already.
hairypete
Post Wed May 24, 2006 11:13 am
aah a very cuning plan gentlemen, thanks, chased up the wishbones and its 40 a side with all the bushes and ball joint in, so thats that bit done.
just the rear end to do now, oh and does anyone know if you can get hold of a panel to replace the rear inner off side wheel arch just behind the fuel filler spout? mine seems to have a bloody great hole through to the boot in it! or is it just plate it and gum it?
Project_E30
Post Wed May 24, 2006 11:57 am
hairypete wrote:aah a very cuning plan gentlemen, thanks, chased up the wishbones and its 40 a side with all the bushes and ball joint in, so thats that bit done.
Can I ask where you got the wishbones with bushes and ball joints for £40??
oze30
Post Wed May 24, 2006 12:12 pm
i thikn the wishbones only have balljoints.. no bushes as above.. i've got to check this though.
Simon
Post Wed May 24, 2006 12:20 pm
hairypete wrote: the wishbones and its 40 a side
He did say per side, normally the bushes are not included, about an extra £10.
dazleeds
old skool raver
old skool raver
Post Wed May 24, 2006 12:21 pm
only thing missing on the ecp wishbones is the rear lollypop bush
but these arent expensive and can be changed fairly easily
i have to do these on the e46 at weekend and they come the same as the e30 ones too
Daz
hairypete
Post Wed May 24, 2006 2:10 pm
got the price from motor components uttoxeter, however the guys there are a little "special" :screwy: , will kinda find out just what i am getting when it arrives sort of thing. but anyways, will be replacing everything on the front and rear by the time im done, gonna give powerflex a miss though, they wont do all the bits i want and bloody hell they aint cheap
