MOT...Gloom & Despondency
M3Tony
Post Tue May 23, 2006 7:38 pm
My 320i convertible just miserably failed.
1/ Nearside & Offside rear flexi hose to metal brake pipe hose ferrule excessively corroded
2/ Nearside front outer ball joint suspension arm has excessive play in a ball joint
3/ Nearside rear bush from sub-frame to body sub-frame rubber bush deteriorated resulting in excessive movement
4/ Offside rear mounting bush from sub-frame to body sub-frame rubber bush deteriorated resulting in excessive movement.
Any cheerful thoughts appreciated.
Garage reckons £600 +/- £100, cash-in-hand for that lot. I ain't capable of any of it, but sounds like some tricky tasks and specific tools needed.
Tony
Oxfordshire
Chris-W
Post Tue May 23, 2006 7:56 pm
That sounds a bit toppy to me, frankly.
If you want to drop it off, I'll do the work & re-MOT it for £300!
Sidrick
Post Tue May 23, 2006 8:24 pm
As Chris said, that's too expensive. The cost of these parts is less than £100, £150 at an absolute limit. I'd say circa 4 hours labour to fit them all.
Take it to a better garage mate :wink:
M3Tony
Post Tue May 23, 2006 9:24 pm
Chris you have pm, Tony
fuzzy
He who sleeps with "Gingers"
Post Tue May 23, 2006 9:56 pm
£600 cash in hand :eek: thats very excessive,get someone elses to do it and report the garage to the inland revenue for doing cash in hand work :D
only joking about reporting them btw winkeye
M3Tony
Post Wed May 31, 2006 5:42 pm
All done and sorted, with fresh MOT - huge thanks to Chris-W !!
Tony
