E30 M3 Calipers??
QuiKie
Post Sun May 21, 2006 2:02 pm
Can these be fitted to an other E30 coupe with out any hassle?
QuiKie
Post Sun May 21, 2006 5:38 pm
:roll:
Aico
Post Mon May 22, 2006 12:13 am
I think the bolts are mounted in a different place, but I'm not sure. You would also redrill the M3 disks to 4x100.
WerkdE30
Post Mon May 22, 2006 12:30 pm
as i understand you need spacers to mount the calipers as they sit further out because of the larger disc. u can re-drill the discs to 4x100 i think not weakening them too much. or put m3 hubs in and e36 compact rear suspension set up. then you also have 5 stud pattern aswell as m3 brakes.
if u know anyone who knows german or speak it yourself then www.e30.de should be of great help.
