Poor Radio Reception
TouringMatt
Post Wed May 17, 2006 4:12 pm
Got a Pioneer HU and im getting poor reception again, fixed it last time by removing the aerial mast (Touring) and cleaning up the connections but its not helped this time
What little reception i have seems to be effected when using the wipers!
Do E30 aerial use amplifiers to boost signal?
Not the most technical of questions but would appreciate some help :)
Matt
TouringMatt
Post Thu May 18, 2006 4:48 pm
Looks like another Teflon coated thread again :mad:
6 views, nice
Martinaston
Post Thu May 18, 2006 5:30 pm
Any joins in the aeriel wire?
MONSPORT42
Post Thu May 18, 2006 5:32 pm
I'm hopeless at electrics but I'm sure there are other items of kit on the radio circuit and it would probably be a good idea to look at the connections/earthing on those. If you have the handbook it shows what kit runs on which fuse circuits which should give you a clue where to look.
Just been to the garage to get mine. Fuse 12 Radio, Check control & instruments. Fuse 21 Interior & glove box lights, torch, clock, radio memory, on-board computer. Fuse 28 Cigarette lighter, electric arial. independent fuel burning heater.
Most radios used to have an arial 'trimming' screw which might need adjusting if you have one. Hopefully someone else will come in with some more concrete advice though! Good luck.
YOUR LEFT FOOT'S FOR BRAKING
Post Thu May 18, 2006 8:49 pm
No
Post Thu May 18, 2006 8:52 pm
MONSPORT42 wrote: Most radios used to have an arial 'trimming' screw which might need adjusting if you have one.
This was for MW reception rather than VHF.
Post Thu May 18, 2006 8:59 pm
Not much to go wrong with a touring aerial TBH.
Check the aerial braid is earthing properly at the roof end andthe wire isn't damaged at the plug end.
MONSPORT42
Post Thu May 18, 2006 9:00 pm
Showing my age Brian. My first car was an MG Magnette ZA - it had a valve radio!
Post Thu May 18, 2006 9:11 pm
MONSPORT42 wrote:Showing my age Brian. My first car was an MG Magnette ZA - it had a valve radio!
Someone on here older than me!! I've had radios (wireless's) with AF117s in them, but never valves!
TouringMatt
Post Thu May 18, 2006 9:40 pm
Thanks for the replys guys, at least i have an idea of what and what not to look for :)
Plug end is sound, tried to get the plastic cover out of the headling to check the aerial end but it its real difficult, feels likes its going to break!
Matt
Markey
Post Thu May 18, 2006 10:04 pm
I was having this problem i found i had to get another booster that plugs in at the radio end.
Also on the IS i had to get a new ariel as i could only get radio 1 Arrrrrrrgh
Post Thu May 18, 2006 10:19 pm
Markey wrote:had to get a new ariel as i could only get radio 1 Arrrrrrrgh
Gutted for ya mate 8O
MONSPORT42
Post Thu May 18, 2006 10:21 pm
Halfords fitted my Kenwood radio and I seem to remember that the E30 required an extra part to make it work with modern head units. May have been a booster of some sort. Might be an idea to get a quote from them and enquire what would be involved. Don't have to take it but at least you'll know without any more trial and error! The thing that keeps me thinking it's an earthing issue is that reception is worse with the wipers on.
Post Thu May 18, 2006 10:28 pm
MONSPORT42 wrote:Halfords fitted my Kenwood radio and I seem to remember that the E30 required an extra part to make it work with modern head units. .
Only late E30s are fitted with an ISO radio connector as standard.Earlier E30s would need this fitted to take a modern radio, and an adaptor on the aerial lead as well.
Don't think I would let anyone from Halfords near any of my cars' electrics!
MONSPORT42
Post Thu May 18, 2006 10:40 pm
I have to say it was done with some trepidation but as I said earlier in the thread , I'm hopeless with electrics. The other attraction was it was free! Not a great fan of Halfords for anything other than a tin of polish, but I haver to say the individual fitter did a very tidy and thus far (2 years) fault free job. I guess it is all down to individuals, my guy was very interested, took his time and quite obviously new what he was doing.
