Post
Wed May 17, 2006 9:03 am
Fill the tank completely and look carefully for the leak is the obvious advice!
May be a good idea to slide 11 back a bit on the pipe stub first to give a clearer view, and to have some fuel containers handy so that you can drain off some afterwards. Theres a drain plug on the right hand side of the tank, which unscrews OK as long as a) no one's messed up the hex socket before, b) You clean out the socket first, and c) You use a good quality hex driver.
Fuel from a leaking pump O ring also tends to drip down around the area of the stub pipe. To check this one, pull up the rear seat cushion and remove a black oval panel on the right hand side.
IIRC, a new fuel tank is only around £90 from ECP or GSF, so may be worth checking before you go the second hand route.
Nothing difficult in changing the fuel tank (except for access to one particular bolt), but the propshaft and rear exhaust need to come off, so it's not a five minute job.
Your quoted price isn't outrageous, but it's no bargain either.
Check the condition of the rear steel brake lines. They are virtually impossible to change with the tank in place, but relatively easty and cheap to replace with the tank out.
