Anti-Roll Bar Bushes
Wookie
What size (in mm) are the bushes for the front and rear anti-rollbar for the 318i?
DaveD
- E30Zone Wiki Specialist
if you key in your vin no in realoem and look up the requisite parts it will tell you the size
FlappySocks
I did that for my Sport, and it says 20MM. Which Powerflex bushes do I get 19mm or 22mm?
Stuart.
Stuart.
DaveD
ask sal
Cotty
- Hartge Crew
Just get some H&R anti roll bars, they come with bushes.
M5pilot
BMW ones. Don't fit incorrect size bushes.FlappySocks wrote:I did that for my Sport, and it says 20MM. Which Powerflex bushes do I get 19mm or 22mm?![]()
Stuart.
jaistanley
I agree, don't fit incorrect size ones but if the correct sized poly ones are available (and I assume they are) get them..
Poly arb bushes transmit little extra noise but allow greater feedback through the wheel.
I understand the argument against poly bushes, my 318is is poly bushed throughout and is noisey on rough surfaces, but I'd still reccomend the ARB bushes for the increase in feedback. (also the M3 front struts for the revised ARB pick-ups).
Oh, and the front ARB bushes I bought for my 318is are 19mm... I think the back ones are 14mm but not 100% on that one.
Jai
Jai
FlappySocks
Thanks for the advice. I'm only changing the bushes because I have to, and seemed to make sense to look at alternatives. I'm happy with the suspension setup as it is anyway. I have plenty of other mods to be getting on with first.
Stuart.
Stuart.
DaveD
if you are changing the bushes you WILL need the link arms as they are usually shot...£26 each from the stealers ...i believe that they are much cheaper from eurocarparts
FlappySocks
Yeah, thay look ok, but they are on my shopping list too. Eurocarparts dont seem to do them.
Stuart.
Stuart.
Bob_S
euro car prats in chester dont know their arse from elbow so wouldnt go there shop somewhere else.
sorry cant help with bushes tho
Bollocks to this 24v scrap!
stonesie
it's not worth going to ECP when the dealer sells them for £2.60 + vat
With trade discount i have just got a pair of ARB bushes and shackles for £5.95 inc vat for my 320
Motronic to Megasquirt Plug and Play Guide
