TroyAndEddie
Post
Sat Apr 29, 2006 11:03 pm
Can anyone tell me where the vacuum hose #22 leads to? It's connected to the carb actuator and the other end is just sitting there next to fuse box connected to nothing. Thanks!
BTW: It's an '87 316.
Martinaston
Post
Sat Apr 29, 2006 11:17 pm
On the five series it plugged into a temp sensor above the glovebox, not sure about the three though
TroyAndEddie
Post
Sat Apr 29, 2006 11:46 pm
Yeah, the disconnected end is on the driver's side, sitting right next to the fuse box and brake booster (?). It does have very slight suction when the throttle is released, so I know it should be hooked up somewhere. I may just take out the fuse box tomorrow and see what's underneath that it may hook up to.
TroyAndEddie
Post
Sun Apr 30, 2006 6:19 pm
No dice today...
Anyone out there with a carb'ed 3-series besides me?
TroyAndEddie
Post
Sat May 06, 2006 11:47 pm
Bumpity bump bump.
I'm taking pics tomorrow.
dazleeds
- old skool raver
Post
Sat May 06, 2006 11:50 pm
im pretty sure it should go to a little square box on the bulkhead with a white cap on it
then back out and to the clocks iirc
TroyAndEddie
Post
Sun May 07, 2006 2:22 pm
Here's the hose
This is a pic of what the hose is connected to underneath. I couldn't take the filter housing off because of the dang rain.
The box with white cap seems to have all the hoses hooked up properly.
TroyAndEddie
Post
Sat May 13, 2006 4:36 pm
Here are some better pictures:
Anyone out there know where this hose goes???
TroyAndEddie
Post
Sun May 14, 2006 7:16 pm
I can't be the only fool with a carb on here....can I?
TroyAndEddie
Post
Tue May 16, 2006 10:00 pm
Someone has to have a Pierburg out there.
This hose is driving me nuts, I've searched this entire bay!
Martinaston
Post
Tue May 16, 2006 11:17 pm
The white piece is just an inline filter and i think the other end just plugs into the passenger compartment so it doesn't draw in damp air
so you may be looking for just a small pipe that goes through the bulkhead.
TroyAndEddie
Post
Wed May 17, 2006 5:14 pm
At least that explains why there are no missing connections in the engine compartment. Thanks!
