tickle
Post
Sat May 13, 2006 9:45 pm
does anybody know if i will pass an mot without the heater unit in?
thinking along the lines of the windscreen de-misting function,
cheers
Cars and girlfriends have alot in common.
They both make you angry+ make you cry, bleed your wallet + moan when they are old.
But at least the car makes sense!
bigdek
Post
Sat May 13, 2006 9:59 pm
yes it will be fine
tickle
Post
Sat May 13, 2006 10:06 pm
excellent, dya reckon im best off fittin a unit or will my windows de-mist sufficiently by opening the windows?
i need to ask as i can't simply test it as im not back on the road yet
i want to remove as much as possible to save on weight
Rich_W
Post
Sat May 13, 2006 10:11 pm
Heater is NOT part of the MOT. Though you could always get a heated front screen fitted.
Post
Sat May 13, 2006 10:16 pm
Rich_W wrote:Heater is NOT part of the MOT. Though you could always get a heated front screen fitted.
Demister is required by SVA though, so presumably it's part of construction and use (or whatever that's called these days), so possibly the car could bre considered to be not road legal.
tickle
Post
Sat May 13, 2006 10:23 pm
i take it that elec windscreens are readily availiable then?
that sounds like the route that i want to take.
12345kevin
Post
Sat May 13, 2006 11:05 pm
I think "kit cars" use a small electric fan connected to windscreen vent to pass "SVA". Would probably suffice for demisting duties
Rich_W
Post
Sat May 13, 2006 11:06 pm
Brianmoooore wrote:Rich_W wrote:Heater is NOT part of the MOT. Though you could always get a heated front screen fitted.
Not sure that many Kit Cars have heaters. Stuff like Caterhams probably wont have one.
re Heated screen, no idea where to get one or how to fit it really. Big relay I guess
Post
Sat May 13, 2006 11:14 pm
Any that have full screens and have gone through SVA will have had a screen demister of some sort at the time of the test.
IIRC, Ford has the patent on heated front screens, and aren't too keen on sharing it.
Andy335Touring
Post
Sat May 13, 2006 11:32 pm
I think i read some where that some one was using two rear E36 Cabriolet demister/heater/fan things in place of the normal heater matrix and fan to de-mist his wind screen ?
Might have been that stripped out LS1 powered E30 M3 that was in TBMW ?
Post
Sun May 14, 2006 12:00 am
Kit car suppliers sell 12V hair drier type things for the job.
jokipea
Post
Sun May 14, 2006 12:18 am
I have a kit-car without a heater, passes MOT OK. Brianmoooore is correct that all new kit-cars must have some method of demisting front screen to pass SVA. Some of the guys building kit-cars fit camping/caravan hair-driers that run on 12v to get around this.
oze30
miniblob
Post
Mon May 15, 2006 1:19 am
Never had one in my mini, just open the side windows a bit!!!
These guys sell a heated front screen for the M3:
http://www.heatedwindscreen.com/acatalo ... reens.html
Same fitment???
I know there is another site that do a huge range of heated front screens but i can't find it!! Nearly bought one for my mini and i think they're available for pretty much any car if you can find the company!!
