Audi Gauges
Quaser
Hi Guys
Has anyone fitted a set of audi gauges to their e30's?
If so, how do you get the oil pressure and oil temp setup, and where do you tap into the signal for them?
Q
Q
Widge
Ive collected all the parts and will be doing this mod when I cahnge the clutch and gearbox on my touring.
You use an M3 tempsensor in place of the sump plug for the oil temp, and a VW /Audi pressure sensor in the block with the right adaptor for the pressure, it also has a connection for the idiot light on the dash, so there is no need for tee pieces etc. And that's about it.
panesar_e30
karan had these audi 80 vdo guages fitted to his car, he should be able to help you quaser.
Widge
IF you need any help mate with the sensors or wiring, just drop me an email widgeewo@btinternet.com
Quaser
email sent to widge
Got a pic of these Widge?
Nice
Better than a heater vent that never gets used
stevetigger
Im thinking in front of ash trayDanThe wrote:NiceBetter than a heater vent that never gets used
But then where would all the crap go
I meant crap as in general, change, phone, keys, all that stuff that needs to go in a hole
maxfield
In your pocket
stevetigger
Hole would stay, I meant in front of the hole thing, (key money junk) holderDanThe wrote:I meant crap as in general, change, phone, keys, all that stuff that needs to go in a hole
GDBN
I've just ordered a voltmeter and oil temp gauge. New VDO ones from a german site. 100 euro including delivery for both and a temp sender.
I thought the same as Steve ... the panel under the heater controls should be fine. You can take a feed from the ashtray light for the internal lights. Just wondering where the best place is to wire in the voltmeter as I use the fag lighter pos for my heated seats.
Giles
Giles
liam012
any pics floating about with these installed in the e30?
will they squeeze into the centre air vent area?
look really nice and very well suited to e30 interior.
Widge
Away for the weekend, will get back to you guys on monday re emails. Heres dodgy photos of mine installed
http://www.e30zone.co.uk/modules.php?na ... light=audi
liam012
cheers
they're nice allright
