Twin 60mm TB'd M30 and manifold cosmectics
Andy335Touring
Fri May 05, 2006 12:18 am
OK.......so i've been a lazy arse and i have had this TB for ages, but i've actually started working to fit the bloody thing ! :)
(I thoght i'd post this in this section for all the 335er's)
I bought a spare manifold to go on my car whilst i work on my port matched manifold/TB so i can still use the car.
Swapping the manifold/injectors/fuel rail/TB/etc isn't straight forward on my car because the servo is to close to the manifold so you can't pull it of the head studs :?
So undo the master cylinder and pull it forward, glove box out and undo the servo bolts, pull the servo out the way and the rest of the job was straight forward. It took me about 3 or so hours at a fairly relaxed pace to swap all the parts over.
Lets get busy with the angle grinder, no going back now ! :twisted:
This is the first rough cut hole which was care fully enlarged to fit the adapter plate later on.
In side the manifold.
The inside edges of the hole i cut were chamfered/rounded off so the air doesn't have any sharp edges/angles to obstruct it's flow in side the plenum.
The mating face on the manifold i thought was fairly flat has a nice curve :? So cut the long sides of the hole in the manifold so that the adapter plate only sit's on top of the manifold on the short sides and the long sides sit "in" the hole.
before..........
and after...........
This is the face of the adapter plate that is in side the plenum, so the air doesn't have to go around a nasty 90 degree edge as it enters the plenum i rounded the edge's of the two holes with a file.
One down one to go, oh i had so much fun with the file :mad: :)
Off to the engineering shop who can TIG weld cast alloy.
Original TB hole blanked of
Adapter plate welded on and new TB bolted on, they look like nice tidy welds that should be air tight once painted(incase theres any tiny pin holes ?)
They also drilled a hole in this spare piece of 20mm alloy for me because i didn't have a big enough drill bit. This piece of alloy is going to house the TPS adapter the Alex kindly made for me as the Ford TB has a flat blade type TPS spindle and i need the normal "D" TPS spindle.
Things to do.........
Make a card board gasket for the TB
Cross my fingers that i can use my old throttle cable and make a new bracket
fit M30 air box and cross my fingers that the E46 M3 intake elows/elbow that Ian is kindly giving me will fit both the TB and the air box
paint manifold and re-fit
Which leeds me on to my manifold cosmectics question, i will be using the same textured/wrinkle effect black paint that i have used on my rocker cover as the texture will help to hide any rough areas on the manifold like the grinding marks i caused when i cleaned the metal up so it was ready to weld.
The question is should i bother grinding smooth the TIG welds and i was also thinking of grinding off the casting seems of the manifold to sort of tidy it up if you know what i mean ?
I also could grind off the old throttle cable bracket mount ?
What do you think ?
stevetigger
Fri May 05, 2006 12:30 am
Im thinking pure sexy!
Fri May 05, 2006 1:37 am
leave the welds but do the rest imo
Chaos
Fri May 05, 2006 2:14 am
whats the tb from Andy ?
Chaos
causing havoc and mayhem wherever i go
Fri May 05, 2006 9:01 am
That looks great Andy, apart from those big ugly bolts :(
Now get some cap-screws in it! :wink:
I would just smooth the weld on the blanking plate "carfully" :lol:
Smooth out the rest of the casting marks and it will look A1 :cool:
Toby_Unna
Boost Junkie
Fri May 05, 2006 9:20 am
looking pretty good Andy 8)
Widge
Fri May 05, 2006 11:05 am
Smoth everything, except the welds, good welding shouldn't need grinding flat, and welds as sexy as that should be left. Deffo grind off the old cable mount.
Good job mate.
Turbo-Brown
Boost Junkie
Fri May 05, 2006 1:24 pm
Oooooh now that is sexy!
The welding looks bloody brilliant too!
Did wonder how you were gonna attach that throttle body, guess I know now :D
Andy335Touring
Fri May 05, 2006 5:10 pm
Chaos wrote:whats the tb from Andy ?
It's from a US Ford V8 32v of some kind, sorry i can't remember exactly which model it came from but if you browse the ebay.com for TB's theres loads on there for not much money.
Danthe wrote: That looks great Andy, apart from those big ugly bolts
Theres a bit of a story behind those bolts as Captin Fuck Up invaded my brain temporarily ! :mad: :)
I'd got some new M8 studs and nuts left over from another job that i was going to use but instead of picking up a 7mm drill bit i picked up an 8mm some how so the holes were too big ! :cheese:
So i had to use M10 instead :oops:
Thanks for all your feed back guys :thumb:
The biggest hinderence(sp?) to getting this on and running is the lack of a lap top to change the fueling on my Emerald ECU, i was going to buy one but i've just forked out £333 for my car insurance.
It's a shame because Dell has got a special offer on for a basic lap top for £300 inc VAT + delivery :(
lentec
Boost Junkie
Fri May 05, 2006 5:18 pm
Bloody good job mate :cool:
Andy335Touring wrote:It's a shame because Dell has got a special offer on for a basic lap top for £300 inc VAT + delivery :(
Thing is that wont have a serial port! IMO anything with win98 will be more than enough and will have a serial port for sure :D
If you only want it for mapping i will see what i can get hold of from work if you like :cool:
Toby_Unna
Boost Junkie
Fri May 05, 2006 5:28 pm
pretty sure that cheap dell is the one my girlfriend's just got Andy, as Len says, no serial port :(
i got an older second hand dell from ebay, higher spec than that new one and old enough to still have a serial port
Andy335Touring
Fri May 05, 2006 5:30 pm
lentec wrote:Bloody good job mate :cool:
Cheers mate, that will be very handy if you could sort some thing out for me, thanks ! 8)
TBH i havn't got a clue about lap tops so i was looking at the Dell lap top as a safe/fuss free option.
________________________________
I forgot to post a picture of the wrinkle paint that i want to use on the manifold :roll:
charlE30
Sat May 06, 2006 8:22 am
That looks awesome Andy, nice work :cool: I've got a load of proper gasket sheets somewhere, if you let me know the approx size I'll stick some in the post for ya :thumb:
Charlie
BMW F31 335d xdrive
Gravy
Sat May 06, 2006 1:02 pm
Mate that looks awesome! You don't hang around much do you! That looks really good all hooked up together, nicely done - the welding looks pukka imo, I would definately leave it as neat weld such as that is pure artwork!
On a different note, I may have found a solution to where I can build my 335i, so i can start collecting bits again as I had put it on hold!
As soon as I have all the bits (not sure how long that will take as funds are tight just now!) I think I may be bending your ear a bit if you don't mind mate! winkeye
Andy335Touring
Sat May 06, 2006 8:07 pm
charlE30 wrote:That looks awesome Andy, nice work :cool: I've got a load of proper gasket sheets somewhere, if you let me know the approx size I'll stick some in the post for ya :thumb:
Charlie
Thanks a lot for the offer mate, i'll drop you a PM in a mo :thumb:
Andy
d6dph
Sat May 06, 2006 8:10 pm
Very impressed with the quality of the welds, it'd be a shame to loose them.
How do you guys work out the ways to do all these things?
Andy335Touring
Sat May 06, 2006 8:18 pm
Gravy wrote:Mate that looks awesome! You don't hang around much do you! That looks really good all hooked up together, nicely done - the welding looks pukka imo, I would definately leave it as neat weld such as that is pure artwork!
I'm glad you have over come that little set back mate, if i can help you out i will, as you are just up the road from me if you need a spare pair of hands during the swap i'll try to pop over. :thumb:
Gravy
Sun May 07, 2006 12:12 am
Andy335Touring wrote:.......as you are just up the road from me if you need a spare pair of hands during the swap i'll try to pop over. :thumb:
Bonza, get involved! Well, when i'm ready to get started that is! :mad:
glenn
Engine Transplant Services
Sun May 07, 2006 7:56 am
those welds look brilliant andy
good work mate
bigkev
Sun May 07, 2006 10:33 am
try these guys for bolts andy they have an awesome selection and you dont have to get off you're backside to order :D
http://www.bsr-aerotek.com/store/index.php
ed325i
Wed May 10, 2006 11:24 am
Andy how are you getting on with it ? werent you going to fit these.
ED
Wed May 10, 2006 8:33 pm
routing through a box of parts today I found these and thought of your manifold!
Any good to ya?
If so just pm me your address and i will pop em in an envelope for ya mate :wink:
Andy335Touring
Wed May 10, 2006 10:29 pm
ed325i wrote:Andy how are you getting on with it ? werent you going to fit these.
ED
Change of plans, the M5 ITB's might make an appearance eventually
Andy335Touring
Wed May 10, 2006 10:33 pm
DanThe wrote:routing through a box of parts today I found these and thought of your manifold!
Any good to ya?
Thanks for the off mate but i'll stick with the bolts as i had to chop them down to fit so i'll probobly have to do the same with those allen bolts.
Andy
buster
Thu May 11, 2006 10:21 am
that looks awesome andy , top job.You should see a good performance gain from that. :cool:
Andy335Touring
Thu May 11, 2006 11:47 am
buster wrote:that looks awesome andy , top job.You should see a good performance gain from that. :cool:
Yeah, touch wood ! :)
