Remving de chrome trim
demonbiker
whats the best way to get the trim off without damage- got one side off but had to bend it a little- will be fine to refit(didnt kink it!)
'90 M5 3.6 "Driven Hard......Put Away Wet!! "
pete325i
I've just used some black insulation tape, if done carefully can look really nice.
Pete
Pete
luxconvertible
best way to do it is with a bit of plastic i personally use filler spreaders at work then lift up with a trim tool or a blunt scew driver!![i work in a body shop and remove quite a lot of trims!!]
good luck Ben
good luck Ben
demonbiker
will it give it a go cheers!
