Post
Mon May 08, 2006 8:46 pm
Looks to me like the mount has been fitted in the wrong hole on the crossmember.
There's two holes (inner & outer). The mount stud should go through the inner hole and a small locating pin should go in the outer hole. I would say someone has managed to fit the stud in the outer hole and the locating pin in the inner hole.
The fact that the rubber of the mount is up against the chassis rail also suggests it's in the wrong hole as there should be a gap between the two.
Ian.
