sunroof removal
325i-sport
hi guys I cant be bothered to look in the haynes as it realy gets on my tits as its useless. but as the topic suggests really, i just want to remove the pannel and install it on another vehicle. what the best way to get it out open tilit or all the way and what do i have to do? how long will it take me. cheers
Only thing Hayne's says about the sunroof is don't touch it.
Open the roof about 1/3 of the way back, and pull down the front of the liner with your hands. It's held up by six or seven spring clips. When it's loose slide it back out of the way.
Now put the roof in the tilt position and you will see three torx screws each side, looking from inside the car outwards. Remove these and the steel panel lifts out.
325i-sport
nice one fella will give it a shot when the shitty weather dissapears for a few hours.
oze30
are the manual and elec roofs the same.. just different internals? how to remove the whole cable thingy??
Mechanism in the motor/handle area consists of two metal plates riveted together. A black one in front and a gold coloured one behind it.
Conversion can be done by just changing the manual black plate for the electric one complete with motor, but there is a minor problem which will occur regards fitting the motor.
Best way to do it is to fit the electric motor mech complete with the guide tubes. Just wind the manual mech off the flex cables, and then wind them into the electric mech tubes. Close the roof completely, remove the motor from the plate, use the switch to set the motor to fully closed, and then refit it. All timed perfectly.
oze30
does it matter if my cables are fooked? they no longer have the plastic sheathing.. and just bunch up in the roof panel instead of stying in the guides. Could I get the cables as well.. and just do as you said?
You can change the cables as well if you need to.
Beware of the edges of the stainless steel plates that hold the roof end of the cables in place. THEY ARE SHARP!
oze30
right.. so I can do this I think. How to remove the opld roof when it's jammed shut. One side opens, the other doesnt. I#ve tried belting it, but no joy. Jant even get the roof to open its that knackered. Wanna help me if I bring it down to you brian?
