indicator flicking abit TOO quick!?
Giggz
Post Tue May 02, 2006 7:58 pm
When i indicate left the indicator is flicking 10 times quicker than it should. I noticed that the back is flashing as is the side repeater but the front indicator is not. Is it a case of changing the bulb or is it the relay/fuse? Where do i start to look?
Thanks in advance.
massive
Post Tue May 02, 2006 7:59 pm
Just the Bulb
Giggz
Post Tue May 02, 2006 8:00 pm
Nice one mate. Bloody hell that was a quick response! Will get it sorted tommorrow. :D
Post Tue May 02, 2006 8:51 pm
May not even need a new bulb.
E30 front indicators aren't particularly waterproof, and, although the lamp holder doesn't corrode, the lamp does.
Try cleaning the metal parts of the lamp before you bin it.
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Tue May 02, 2006 9:07 pm
Brianmoooore wrote:May not even need a new bulb.
And your top tip for the day is dab a bit of grease over the end cap of the bulb and it won't corrode again. winkeye
Taylor.
Taylor325i
Post Tue May 02, 2006 9:10 pm
Taylor.
Or if you wanna be anal about it (pardon the punn) and not use grease then vaseline works just as good. :gay:
Taylor.
Post Tue May 02, 2006 9:19 pm
Silicon grease is the stuff to use.
