Service re-setting tool?
herman
Got the device but no destructions, how does it work?
dannosail
Herman,
I don't mean to be a kill joy
but this is the way I did it when my car battery died and the Inspection light came on before its time:
Unscrew the cap and you'll see a number of connectors in accordance with the diagram below (if you have the old style connector I also have a picture).
· According to the type of plug on your car, locate the right connectors, marked red in the diagrams;
· Use the jumper wire to connect them together;
· Turn the key to ON position, without starting the car;
· When the 5 LED's in the dash light up (3/4 seconds), turn off the key. If you keep the ignition on, another 6/7 seconds, after the LED's appear, you'll perform an inspection reset, too.
· Disconnect the jumper wire.[/img]
unless it was free, it's an expensive six inches of wire.herman wrote:Got the device but no destructions, how does it work?
herman
Cheers I'll try that
dobbie82
- Location: Dolgellau, Wales (NOT A TRADER,broken a car,got lots of bits)
I have a £9.99 draper 6 inches of wireBrianmoooore wrote:unless it was free, it's an expensive six inches of wire.herman wrote:Got the device but no destructions, how does it work?
herman
Is that code for something?
herman
It worked tho!!!I have a £9.99 draper 6 inches of wire
Its not code. I've got one of them aswell, £8 I think it was from a zoner.
delboy8000
sorry to be a total mechanical know-nil,but what kind of wire do you use?metal or fuse wire?
smithy318i
a paperclip will do !delboy8000 wrote:sorry to be a total mechanical know-nil,but what kind of wire do you use?metal or fuse wire?
Just an ordinary bog standard piece of PVC covered flexible wire, with 10mm of insulation removed at each end - or Smithy318i's paperclip.delboy8000 wrote:sorry to be a total mechanical know-nil,but what kind of wire do you use?metal or fuse wire?
delboy8000
thanks guys,will try asapBrianmoooore wrote:Just an ordinary bog standard piece of PVC covered flexible wire, with 10mm of insulation removed at each end - or Smithy318i's paperclip.delboy8000 wrote:sorry to be a total mechanical know-nil,but what kind of wire do you use?metal or fuse wire?
