stuts
jordano
Post Fri Apr 28, 2006 9:41 pm
Does anyone know if i need a special tool to remove the nut to change the shock insert problem i have i everything is turning when i put a socket on but i cant get at thelittle nipple at the top to stop it, any ideas?
worrying is like a rocking chair, it gives you something to do but it never really gets you anywhere
Simon
Post Fri Apr 28, 2006 10:09 pm
gcorky
Boost Junkie
Post Fri Apr 28, 2006 10:11 pm
use a socket and grips on big nut with a deep socket through middle i.e 1/4 drive.people usually loosen prior to removal,weight of vehicle helps hold. :cool:
525 sport
