who has fitted tec1 (clips mounts rubber strips advice)
liam012
Post Thu Apr 27, 2006 11:02 am
Well i have sourced all my tec 1 kit
it hasalmost none of the fixings though
is tee such thing as exploded diagrams for howthey are fitted with part numbers for the fuddly bits?
do yu have to get a template i heard too?
any advice on fitting a tec1 wod e super
thanks
Stealth
Post Thu Apr 27, 2006 11:05 am
Liam,
you have PM
Stealth
Post Thu Apr 27, 2006 11:08 am
Theo
Post Thu Apr 27, 2006 11:10 am
Hi Liam,
http://www.realoem.com/bmw/partgrp.do?m ... 7283&hg=51
browse through here, should be very helpful, quite hard to understand exactly what is needed for the sideskirts though, these are the only bits I havent fitted to my car yet. All of the fitting bits are available from BMW still, you will need different rubber bumper end caps for the rear which are bitch to source second hand, and are about £42 each from BMW new! Its a fiddly job fitting the kit, you need to remove the bumpers, attach the kit to the bumpers, but the trim on and then persuade it onto the car. A second pair of hands is very very useful.
Theo
liam012
Post Thu Apr 27, 2006 1:18 pm
i actually have the end caps! just not a single screw or clip - the front bumper is at present a one piece with the valance but with removal for spraying i'll need to replace the clips and rusty screws thee two -
thanks for your help
it actually looks like a bit of a challenge
the current enfgine reguild looks less daunting!
